6921 Phones unable to register to CME
Hi guys, so we tried to load a later IOS firmware onto our 2900 router from c2900-universalk9-mz.SPA.151-3.T1.bin
to c2900-universalk9-mz.SPA.154-3.M1.bin by upgrading it via Cisco Prime. Due to space Prime appeared to have deleted some files from flash and after a reboot the phones (6921) have failed to register back to the CME.
show run
#show run
Building configuration...
Current configuration : 13901 bytes
! No configuration change since last restart
version 15.4
service nagle
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service sequence-numbers
hostname 2901-cme
boot-start-marker
boot system flash0:c2900-universalk9-mz.SPA.154-3.M1.bin
boot-end-marker
logging buffered 51200 warnings
no logging console
enable secret 5 $1$GJh/$Or3p08gbuJbmGi71SWW.q.
no aaa new-model
memory-size iomem 10
clock timezone GMT 0 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 1:00
network-clock-participate wic 0
ip dhcp excluded-address 10.20.190.65 10.20.190.70
ip dhcp excluded-address 10.20.169.65 10.20.169.70
ip dhcp pool VOICE
network 10.20.190.64 255.255.255.192
default-router 10.20.190.68
option 150 ip 10.20.190.68
lease 14
ip dhcp pool VOICE_NEW
network 10.20.169.64 255.255.255.192
default-router 10.20.169.68
option 150 ip 10.20.169.68
lease 14
no ip domain lookup
ip domain name domain.net
ip cef
no ipv6 cef
isdn switch-type basic-net3
trunk group PSTN-ISDN
max-calls voice 4
voice-class cause-code 1
description **4 BRI Ports**
hunt-scheme round-robin
translation-profile incoming Add9
cts logging verbose
crypto pki trustpoint TP-self-signed-2514939144
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2514939144
revocation-check none
rsakeypair TP-self-signed-2514939144
crypto pki certificate chain TP-self-signed-2514939144
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32353134 39333931 3434301E 170D3139 30383136 30373437
32345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 35313439
33393134 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100A812 AF885C9A 883C142C 6A346124 6F3C8C54 20AB23F8 9EA828FD 12210DDA
B722A25E C179746B C0B3828A 736FE6DE B3A667BA 2D50C742 A33B3A67 2C28ADF8
B7E26219 3BFD4746 A9195283 42522D86 91157299 7C873D9B 771B3AD4 EF85FCCB
6457FE60 EAAD1481 BEDD65B6 144C9D3B EE7863C3 BF572985 BF32A88C ECEB139B
74DB0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 143FD5CB BA135B5D 2C34C869 69BFB50A CA7C3C1A 6C301D06
03551D0E 04160414 3FD5CBBA 135B5D2C 34C86969 BFB50ACA 7C3C1A6C 300D0609
2A864886 F70D0101 04050003 81810083 4B321AB5 EEB9355E C5BA4C2A 5AF493C6
C56203BE 24C1CFE5 A6DA165F D40C96B7 BB333778 7892E311 E71D7876 9E97B766
28DDD243 80A871E6 6F9D7EAC 7C118949 2CDA89CF 459E411D 6342D56A 6EA299D4
EBF25F6C 9B4CB3B3 CB9D2773 C35E4A22 0EA60ED7 E9D0B316 E9EB2A69 EDAF8393
1FD9DB9D 67682E8F 8193BDCB 6F10A1
quit
voice-card 0
voice service voip
ip address trusted list
ipv4 10.20.190.68
ipv4 10.20.190.69
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729br8
voice class h323 1
h225 timeout tcp establish 3
voice register global
mode cme
voice hunt-group 1 parallel
final 2199
list 2106,2107
pilot 2100
voice translation-rule 20
rule 1 // /90/ type national national
rule 2 // /900/ type international international
voice translation-profile Add9
translate calling 20
license udi pid CISCO2901/K9 sn FCZ151092KK
hw-module ism 0
hw-module pvdm 0/0
archive
path ftp://10.20.66.6/running-config/$h
write-memory
time-period 10080
username ansgroup privilege 15 secret 5 $1$NKF8$MKlu7qMUQvXzX65Nr70s.0
username CWorks privilege 15 secret 5 $1$Igfd$W6cym6.WLbum5LOnLV5.m0
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description DATA Network
ip address 10.20.169.6 255.255.255.192
duplex auto
speed auto
interface ISM0/0
ip unnumbered GigabitEthernet0/1
service-module ip address 10.20.190.69 255.255.255.192
!Application: CUE Running on ISM
service-module ip default-gateway 10.20.190.68
interface GigabitEthernet0/1
description VOICE Network$ES_LAN$
ip address 10.20.190.68 255.255.255.192
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
shutdown
interface BRI0/0/0
description ** ISDN L3 & L4 **
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
isdn static-tei 0
trunk-group PSTN-ISDN
interface BRI0/0/1
description ** ISDN L1 & L2 **
no ip address
isdn static-tei 0
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:cme/gui
ip route 0.0.0.0 0.0.0.0 10.20.169.1
ip route 10.20.190.69 255.255.255.255 ISM0/0
logging trap errors
logging host 10.20.10.200
snmp-server community public RO
snmp-server community trust RW
snmp-server community prtgro RO
snmp-server host 10.20.10.240 trust
tftp-server flash:cme/SCCP69xx.9-1-1-0.zz.sgn
tftp-server flash:cme/DSP69xx.0-0-0-4.zz.sgn
tftp-server flash:cme/SCCP69xx.9-1-1-0.loads
tftp-server flash:cme/ringtones/Analog1.raw
tftp-server flash:cme/ringtones/Analog2.raw
tftp-server flash:cme/ringtones/AreYouThere.raw
tftp-server flash:cme/ringtones/AreYouThereF.raw
tftp-server flash:cme/ringtones/Bass.raw
tftp-server flash:cme/ringtones/CallBack.raw
tftp-server flash:cme/ringtones/Chime.raw
tftp-server flash:cme/ringtones/Classic1.raw
tftp-server flash:cme/ringtones/Classic2.raw
tftp-server flash:cme/ringtones/ClockShop.raw
tftp-server flash:cme/ringtones/Drums1.raw
tftp-server flash:cme/ringtones/Drums2.raw
tftp-server flash:cme/ringtones/FilmScore.raw
tftp-server flash:cme/ringtones/HarpSynth.raw
tftp-server flash:cme/ringtones/Jamaica.raw
tftp-server flash:cme/ringtones/KotoEffect.raw
tftp-server flash:cme/ringtones/MusicBox.raw
tftp-server flash:cme/ringtones/Piano1.raw
tftp-server flash:cme/ringtones/Piano2.raw
tftp-server flash:cme/ringtones/Pop.raw
tftp-server flash:cme/ringtones/Pulse1.raw
tftp-server flash:cme/ringtones/Ring1.raw
tftp-server flash:cme/ringtones/Ring2.raw
tftp-server flash:cme/ringtones/Ring3.raw
tftp-server flash:cme/ringtones/Ring4.raw
tftp-server flash:cme/ringtones/Ring5.raw
tftp-server flash:cme/ringtones/Ring6.raw
tftp-server flash:cme/ringtones/Ring7.raw
tftp-server flash:cme/ringtones/Sax1.raw
tftp-server flash:cme/ringtones/Sax2.raw
tftp-server flash:cme/ringtones/Vibe.raw
tftp-server flash:cme/ringtones/RingList.xml
tftp-server flash:cme/ringtones/DistinctiveRingList.xml
tftp-server flash:cme/CP7921G-1.4.1SR1.LOADS
tftp-server flash:cme/APPS-1.4.1SR1.SBN
tftp-server flash:cme/GUI-1.4.1SR1.SBN
tftp-server flash:cme/SYS-1.4.1SR1.SBN
tftp-server flash:cme/TNUX-1.4.1SR1.SBN
tftp-server flash:cme/TNUXR-1.4.1SR1.SBN
tftp-server flash:cme/WLAN-1.4.1SR1.SBN
tftp-server flash:SCCP69xx.9-4-1-3SR3.loads
tftp-server flash:cme/SCCP69xx.9-1-1-0.zz.sgn alias SCCP69xx.9-1-1-0.zz.sgn
tftp-server flash:cme/DSP69xx.0-0-0-4.zz.sgn alias DSP69xx.0-0-0-4.zz.sgn
tftp-server flash:cme/SCCP69xx.9-1-1-0.loads alias SCCP69xx.9-1-1-0.loads
tftp-server flash:SCCP69xx.9-4-1-3SR3.loads alias SCCP69xx.9-4-1-3SR3.loads
control-plane
voice-port 0/0/0
no vad
compand-type a-law
cptone GB
bearer-cap Speech
voice-port 0/0/1
no vad
compand-type a-law
cptone GB
bearer-cap Speech
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 pots
trunkgroup PSTN-ISDN
description ** Default Dial-Peer **
incoming called-number .
direct-inward-dial
dial-peer voice 10 pots
description ** Outbound PSTN **
destination-pattern 9T
direct-inward-dial
dial-peer voice 999 pots
description ** Emergency Dial-Peer **
destination-pattern 999
forward-digits 3
dial-peer voice 20 pots
trunkgroup ISDN-PSTN
description ** Outbound to Mobiles **
destination-pattern 907.........
forward-digits 11
dial-peer voice 2199 voip
description ** Voicemail Pilot **
destination-pattern 2199
session protocol sipv2
session target ipv4:10.20.190.69
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2198 voip
description ** Voicemail AvT Pilot **
destination-pattern 2198
codec g711ulaw
no vad
num-exp 640002 2100
presence
presence call-list
sip-ua
mwi-server ipv4:10.20.190.69 expires 3600 port 5060 transport udp
presence enable
gatekeeper
shutdown
telephony-service
authentication credential admin cmeadmin111
authentication credential cworks secretpassword
max-ephones 42
max-dn 100
url services http://10.20.190.69/voiceview/common/login.do
url authentication http://10.20.190.68/CCMCIP/authenticate.asp
load 7921 cme/CP7921G-1.4.1SR1
load 6921 SCCP69xx.9-4-1-3SR3.loads
load 6941 SCCP69xx.9-4-1-3SR2
time-format 24
date-format dd-mm-yy
voicemail 2199
max-conferences 8 gain -6
web admin system name admin password cmeadmin111
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp 7960 Aug 16 2019 09:52:20
ephone-dn 1 octo-line
number 2101
pickup-group 1
label Upstairs Office
description Upstairs Office 2101
name Upstairs Office
huntstop channel 2
ephone-dn 2 octo-line
number 2102
pickup-group 1
label Downstairs Office 1
description Downstairs Office 1 2102
name Downstairs Office 1
huntstop channel 2
ephone-dn 3 octo-line
number 2103
pickup-group 1
label Downstairs Office 2
description Downstairs Office 2 2103
name Downstairs Office 2
huntstop channel 2
ephone-dn 4 octo-line
number 2104
pickup-group 1
label Downstairs Office 3
description Downstairs Office 3 2104
name Downstairs Office 3
huntstop channel 2
ephone-dn 5 octo-line
number 2105
pickup-group 1
label Downstairs Office 4
description Downstairs Office 4 2105
name Downstairs Office 4
huntstop channel 2
ephone-dn 6 octo-line
number 2106
pickup-group 1
label Reception 1
description Reception 1 2106
name Reception 1
huntstop channel 2
mwi sip
ephone-dn 7 octo-line
number 2107
pickup-group 1
label Reception 2
description Reception 21 2107
name Reception 2
huntstop channel 2
mwi sip
ephone-dn 8 octo-line
number 2108
pickup-group 1
label Vanessa Newlands
description Vanessa Newlands 2108
name Vanessa Newlands
huntstop channel 2
ephone-dn 9 dual-line
number 2109
pickup-group 1
label Wireless
description Wireless 2109
name Wireless
huntstop channel
ephone 1
mac-address 503D.E52F.C91A
max-calls-per-button 2
type 6921
button 1:1
ephone 2
mac-address 503D.E52F.E9A2
type 6921
button 1:2
ephone 3
mac-address 503D.E52F.C08D
type 6921
button 1:3
ephone 4
mac-address 503D.E52F.BC68
type 6921
button 1:4
ephone 5
mac-address 503D.E52F.BC59
type 6921
button 1:5
ephone 6
mac-address 1CE6.C798.35DC
type 6921
button 1:6
ephone 7
mac-address 503D.E52F.C095
type 6921
button 1:7
ephone 8
mac-address 503D.E52F.C080
type 6921
button 1:8
ephone 9
mac-address 1CDF.0F50.6746
max-calls-per-button 4
type 7921
button 1:9
ephone 10
banner login ^C
THIS DEVICE IS PART OF A
PRIVATE NETWORK
* Unauthorised access or use of this equipment *
* is prohibited and constitutes an offence *
* under the Computer Misuse Act 1990. *
* If you are not authorised to use this *
* system, terminate this session now. *
^C
line con 0
exec-timeout 30 0
privilege level 15
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
line vty 0 4
exec-timeout 30 0
privilege level 15
login local
transport input telnet ssh
line vty 5 15
exec-timeout 30 0
privilege level 15
login local
scheduler allocate 20000 1000
ntp server 10.20.0.61 prefer
end
show flash
#show flash:
-#- --length-- -----date/time------ path
1 104102656 Aug 16 2019 09:26:24 +01:00 c2900-universalk9-mz.SPA.154-3.M1.bin
2 2903 Mar 3 2011 12:32:16 +00:00 cpconfig-29xx.cfg
3 2941440 Mar 3 2011 12:32:32 +00:00 cpexpress.tar
4 1038 Mar 3 2011 12:32:40 +00:00 home.shtml
5 115712 Mar 3 2011 12:32:50 +00:00 home.tar
6 1697952 Mar 3 2011 12:33:04 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
7 415956 Mar 3 2011 12:33:16 +00:00 sslclient-win-1.1.4.176.pkg
8 68218660 Jul 15 2011 12:53:54 +01:00 c2900-universalk9-mz.SPA.151-3.T1.bin
9 0 Jul 15 2011 13:10:20 +01:00 cme
10 496521 Jul 15 2011 13:11:14 +01:00 cme/music-on-hold.au
11 2224248 Jul 15 2011 13:11:20 +01:00 cme/SCCP69xx.9-1-1-0.zz.sgn
12 45308 Jul 15 2011 13:11:22 +01:00 cme/BOOT69xx.0-0-0-14.zz.sgn
13 204456 Jul 15 2011 13:11:22 +01:00 cme/DSP69xx.0-0-0-4.zz.sgn
14 481 Jul 15 2011 13:11:24 +01:00 cme/SCCP69xx.9-1-1-0.loads
15 0 Jul 15 2011 13:11:24 +01:00 cme/gui
16 4118 Jul 15 2011 13:11:24 +01:00 cme/gui/admin_user.html
17 677820 Jul 15 2011 13:11:26 +01:00 cme/gui/admin_user.js
18 1029 Jul 15 2011 13:11:26 +01:00 cme/gui/CiscoLogo.gif
19 639 Jul 15 2011 13:11:28 +01:00 cme/gui/CME_GUI_README.TXT
20 953 Jul 15 2011 13:11:28 +01:00 cme/gui/Delete.gif
21 16344 Jul 15 2011 13:11:28 +01:00 cme/gui/dom.js
22 864 Jul 15 2011 13:11:28 +01:00 cme/gui/downarrow.gif
23 6315 Jul 15 2011 13:11:28 +01:00 cme/gui/ephone_admin.html
24 4558 Jul 15 2011 13:11:30 +01:00 cme/gui/logohome.gif
25 3978 Jul 15 2011 13:11:30 +01:00 cme/gui/normal_user.html
26 78428 Jul 15 2011 13:11:30 +01:00 cme/gui/normal_user.js
27 1347 Jul 15 2011 13:11:30 +01:00 cme/gui/Plus.gif
28 843 Jul 15 2011 13:11:32 +01:00 cme/gui/sxiconad.gif
29 174 Jul 15 2011 13:11:32 +01:00 cme/gui/Tab.gif
30 2496 Jul 15 2011 13:11:32 +01:00 cme/gui/telephony_service.html
31 870 Jul 15 2011 13:11:32 +01:00 cme/gui/uparrow.gif
32 10230 Jul 15 2011 13:11:32 +01:00 cme/gui/xml-test.html
33 3412 Jul 15 2011 13:11:34 +01:00 cme/gui/xml.template
34 0 Jul 15 2011 13:11:34 +01:00 cme/ringtones
35 8160 Jul 15 2011 13:11:34 +01:00 cme/ringtones/Analog1.raw
36 8160 Jul 15 2011 13:11:34 +01:00 cme/ringtones/Analog2.raw
37 5280 Jul 15 2011 13:11:34 +01:00 cme/ringtones/AreYouThere.raw
38 5040 Jul 15 2011 13:11:36 +01:00 cme/ringtones/AreYouThereF.raw
39 8160 Jul 15 2011 13:11:36 +01:00 cme/ringtones/Bass.raw
40 12240 Jul 15 2011 13:11:36 +01:00 cme/ringtones/CallBack.raw
41 16040 Jul 15 2011 13:11:36 +01:00 cme/ringtones/Chime.raw
42 8160 Jul 15 2011 13:11:38 +01:00 cme/ringtones/Classic1.raw
43 16080 Jul 15 2011 13:11:38 +01:00 cme/ringtones/Classic2.raw
44 10800 Jul 15 2011 13:11:38 +01:00 cme/ringtones/ClockShop.raw
45 2823 Jul 15 2011 13:11:38 +01:00 cme/ringtones/DistinctiveRingList.xml
46 9600 Jul 15 2011 13:11:38 +01:00 cme/ringtones/Drums1.raw
47 13440 Jul 15 2011 13:11:40 +01:00 cme/ringtones/Drums2.raw
48 15840 Jul 15 2011 13:11:40 +01:00 cme/ringtones/FilmScore.raw
49 16080 Jul 15 2011 13:11:40 +01:00 cme/ringtones/HarpSynth.raw
50 8160 Jul 15 2011 13:11:40 +01:00 cme/ringtones/Jamaica.raw
51 16080 Jul 15 2011 13:11:42 +01:00 cme/ringtones/KotoEffect.raw
52 12720 Jul 15 2011 13:11:42 +01:00 cme/ringtones/MusicBox.raw
53 8160 Jul 15 2011 13:11:42 +01:00 cme/ringtones/Piano1.raw
54 15360 Jul 15 2011 13:11:42 +01:00 cme/ringtones/Piano2.raw
55 9360 Jul 15 2011 13:11:42 +01:00 cme/ringtones/Pop.raw
56 7200 Jul 15 2011 13:11:44 +01:00 cme/ringtones/Pulse1.raw
57 4000 Jul 15 2011 13:11:44 +01:00 cme/ringtones/Ring1.raw
58 4000 Jul 15 2011 13:11:44 +01:00 cme/ringtones/Ring2.raw
59 4000 Jul 15 2011 13:11:44 +01:00 cme/ringtones/Ring3.raw
60 4000 Jul 15 2011 13:11:44 +01:00 cme/ringtones/Ring4.raw
61 4000 Jul 15 2011 13:11:46 +01:00 cme/ringtones/Ring5.raw
62 4000 Jul 15 2011 13:11:46 +01:00 cme/ringtones/Ring6.raw
63 4000 Jul 15 2011 13:11:46 +01:00 cme/ringtones/Ring7.raw
64 495 Jul 15 2011 13:11:46 +01:00 cme/ringtones/RingList.xml
65 10800 Jul 15 2011 13:11:48 +01:00 cme/ringtones/Sax1.raw
66 14160 Jul 15 2011 13:11:48 +01:00 cme/ringtones/Sax2.raw
67 16080 Jul 15 2011 13:11:48 +01:00 cme/ringtones/Vibe.raw
68 2627982 Jul 15 2011 13:11:56 +01:00 cme/APPS-1.4.1SR1.SBN
69 922 Jul 15 2011 13:11:56 +01:00 cme/CP7921G-1.4.1SR1.LOADS
70 2086148 Jul 15 2011 13:12:02 +01:00 cme/GUI-1.4.1SR1.SBN
71 2083051 Jul 15 2011 13:12:08 +01:00 cme/SYS-1.4.1SR1.SBN
72 896557 Jul 15 2011 13:12:12 +01:00 cme/TNUX-1.4.1SR1.SBN
73 2335746 Jul 15 2011 13:12:18 +01:00 cme/TNUXR-1.4.1SR1.SBN
74 1386134 Jul 15 2011 13:12:24 +01:00 cme/WLAN-1.4.1SR1.SBN
75 0 Jul 15 2011 13:34:54 +01:00 its
76 0 Jul 15 2011 13:34:54 +01:00 its/vrf1
77 405 Aug 15 2019 12:53:20 +01:00 its/vrf1/ATADefault.cnf.xml
78 3185 Aug 15 2019 12:53:20 +01:00 its/vrf1/XMLDefault.cnf.xml
79 1300 Aug 15 2019 12:53:20 +01:00 its/vrf1/XMLDefault6901.cnf.xml
80 1300 Aug 15 2019 12:53:20 +01:00 its/vrf1/XMLDefault6911.cnf.xml
81 1409 Aug 15 2019 12:53:20 +01:00 its/vrf1/XMLDefault6921.cnf.xml
82 1393 Aug 15 2019 12:53:22 +01:00 its/vrf1/XMLDefault6941.cnf.xml
83 1393 Aug 15 2019 12:53:22 +01:00 its/vrf1/XMLDefault6961.cnf.xml
84 520 Aug 15 2019 12:53:22 +01:00 its/vrf1/XMLDefault7902.cnf.xml
85 1019 Aug 15 2019 12:53:22 +01:00 its/vrf1/XMLDefault7905.cnf.xml
86 1300 Aug 15 2019 12:53:22 +01:00 its/vrf1/XMLDefault7906.cnf.xml
87 606 Aug 15 2019 12:53:24 +01:00 its/vrf1/XMLDefault7910.cnf.xml
88 1300 Aug 15 2019 12:53:24 +01:00 its/vrf1/XMLDefault7911.cnf.xml
89 1019 Aug 15 2019 12:53:24 +01:00 its/vrf1/XMLDefault7912.cnf.xml
90 1019 Aug 15 2019 12:53:24 +01:00 its/vrf1/XMLDefault7920.cnf.xml
91 1226 Aug 15 2019 12:53:26 +01:00 its/vrf1/XMLDefault7921.cnf.xml
92 1262 Aug 15 2019 12:53:26 +01:00 its/vrf1/XMLDefault7925.cnf.xml
93 1300 Aug 15 2019 12:53:26 +01:00 its/vrf1/XMLDefault7931.cnf.xml
94 553 Aug 15 2019 12:53:26 +01:00 its/vrf1/XMLDefault7935.cnf.xml
95 553 Aug 15 2019 12:53:26 +01:00 its/vrf1/XMLDefault7936.cnf.xml
96 1300 Aug 15 2019 12:53:28 +01:00 its/vrf1/XMLDefault7937.cnf.xml
97 1271 Aug 15 2019 12:53:28 +01:00 its/vrf1/XMLDefault7940-7914-1.cnf.xml
98 1402 Aug 15 2019 12:53:28 +01:00 its/vrf1/XMLDefault7940-7914-2.cnf.xml
99 1271 Aug 15 2019 12:53:28 +01:00 its/vrf1/XMLDefault7940-7915-12-1.cnf.xml
100 1402 Aug 15 2019 12:53:28 +01:00 its/vrf1/XMLDefault7940-7915-12-2.cnf.xml
101 1271 Aug 15 2019 12:53:30 +01:00 its/vrf1/XMLDefault7940-7915-24-1.cnf.xml
102 1402 Aug 15 2019 12:53:30 +01:00 its/vrf1/XMLDefault7940-7915-24-2.cnf.xml
103 1271 Aug 15 2019 12:53:30 +01:00 its/vrf1/XMLDefault7940-7916-12-1.cnf.xml
104 1402 Aug 15 2019 12:53:30 +01:00 its/vrf1/XMLDefault7940-7916-12-2.cnf.xml
105 1271 Aug 15 2019 12:53:32 +01:00 its/vrf1/XMLDefault7940-7916-24-1.cnf.xml
106 1402 Aug 15 2019 12:53:32 +01:00 its/vrf1/XMLDefault7940-7916-24-2.cnf.xml
107 1109 Aug 15 2019 12:53:32 +01:00 its/vrf1/XMLDefault7940.cnf.xml
108 1300 Aug 15 2019 12:53:32 +01:00 its/vrf1/XMLDefault7941.cnf.xml
109 1300 Aug 15 2019 12:53:32 +01:00 its/vrf1/XMLDefault7941GE.cnf.xml
110 1300 Aug 15 2019 12:53:34 +01:00 its/vrf1/XMLDefault7942.cnf.xml
111 1300 Aug 15 2019 12:53:34 +01:00 its/vrf1/XMLDefault7945.cnf.xml
112 1271 Aug 15 2019 12:53:34 +01:00 its/vrf1/XMLDefault7960-7914-1.cnf.xml
113 1402 Aug 15 2019 12:53:34 +01:00 its/vrf1/XMLDefault7960-7914-2.cnf.xml
114 1271 Aug 15 2019 12:53:34 +01:00 its/vrf1/XMLDefault7960-7915-12-1.cnf.xml
115 1402 Aug 15 2019 12:53:36 +01:00 its/vrf1/XMLDefault7960-7915-12-2.cnf.xml
116 1271 Aug 15 2019 12:53:36 +01:00 its/vrf1/XMLDefault7960-7915-24-1.cnf.xml
117 1402 Aug 15 2019 12:53:36 +01:00 its/vrf1/XMLDefault7960-7915-24-2.cnf.xml
118 1271 Aug 15 2019 12:53:36 +01:00 its/vrf1/XMLDefault7960-7916-12-1.cnf.xml
119 1402 Aug 15 2019 12:53:38 +01:00 its/vrf1/XMLDefault7960-7916-12-2.cnf.xml
120 1271 Aug 15 2019 12:53:38 +01:00 its/vrf1/XMLDefault7960-7916-24-1.cnf.xml
121 1402 Aug 15 2019 12:53:38 +01:00 its/vrf1/XMLDefault7960-7916-24-2.cnf.xml
122 1109 Aug 15 2019 12:53:38 +01:00 its/vrf1/XMLDefault7960.cnf.xml
123 1462 Aug 15 2019 12:53:38 +01:00 its/vrf1/XMLDefault7961-7914-1.cnf.xml
124 1593 Aug 15 2019 12:53:40 +01:00 its/vrf1/XMLDefault7961-7914-2.cnf.xml
125 1462 Aug 15 2019 12:53:40 +01:00 its/vrf1/XMLDefault7961-7915-12-1.cnf.xml
126 1593 Aug 15 2019 12:53:40 +01:00 its/vrf1/XMLDefault7961-7915-12-2.cnf.xml
127 1462 Aug 15 2019 12:53:40 +01:00 its/vrf1/XMLDefault7961-7915-24-1.cnf.xml
128 1593 Aug 15 2019 12:53:42 +01:00 its/vrf1/XMLDefault7961-7915-24-2.cnf.xml
129 1462 Aug 15 2019 12:53:42 +01:00 its/vrf1/XMLDefault7961-7916-12-1.cnf.xml
130 1593 Aug 15 2019 12:53:42 +01:00 its/vrf1/XMLDefault7961-7916-12-2.cnf.xml
131 1462 Aug 15 2019 12:53:42 +01:00 its/vrf1/XMLDefault7961-7916-24-1.cnf.xml
132 1593 Aug 15 2019 12:53:42 +01:00 its/vrf1/XMLDefault7961-7916-24-2.cnf.xml
133 1300 Aug 15 2019 12:53:44 +01:00 its/vrf1/XMLDefault7961.cnf.xml
134 1462 Aug 15 2019 12:53:44 +01:00 its/vrf1/XMLDefault7961GE-7914-1.cnf.xml
135 1593 Aug 15 2019 12:53:44 +01:00 its/vrf1/XMLDefault7961GE-7914-2.cnf.xml
136 1462 Aug 15 2019 12:53:44 +01:00 its/vrf1/XMLDefault7961GE-7915-12-1.cnf.xml
137 1593 Aug 15 2019 12:53:44 +01:00 its/vrf1/XMLDefault7961GE-7915-12-2.cnf.xml
138 1462 Aug 15 2019 12:53:46 +01:00 its/vrf1/XMLDefault7961GE-7915-24-1.cnf.xml
139 1593 Aug 15 2019 12:53:46 +01:00 its/vrf1/XMLDefault7961GE-7915-24-2.cnf.xml
140 1462 Aug 15 2019 12:53:46 +01:00 its/vrf1/XMLDefault7961GE-7916-12-1.cnf.xml
141 1593 Aug 15 2019 12:53:46 +01:00 its/vrf1/XMLDefault7961GE-7916-12-2.cnf.xml
142 1462 Aug 15 2019 12:53:48 +01:00 its/vrf1/XMLDefault7961GE-7916-24-1.cnf.xml
143 1593 Aug 15 2019 12:53:48 +01:00 its/vrf1/XMLDefault7961GE-7916-24-2.cnf.xml
144 1300 Aug 15 2019 12:53:48 +01:00 its/vrf1/XMLDefault7961GE.cnf.xml
145 1462 Aug 15 2019 12:53:48 +01:00 its/vrf1/XMLDefault7962-7914-1.cnf.xml
146 1593 Aug 15 2019 12:53:48 +01:00 its/vrf1/XMLDefault7962-7914-2.cnf.xml
147 1462 Aug 15 2019 12:53:50 +01:00 its/vrf1/XMLDefault7962-7915-12-1.cnf.xml
148 1593 Aug 15 2019 12:53:50 +01:00 its/vrf1/XMLDefault7962-7915-12-2.cnf.xml
149 1462 Aug 15 2019 12:53:50 +01:00 its/vrf1/XMLDefault7962-7915-24-1.cnf.xml
150 1593 Aug 15 2019 12:53:50 +01:00 its/vrf1/XMLDefault7962-7915-24-2.cnf.xml
151 1462 Aug 15 2019 12:53:50 +01:00 its/vrf1/XMLDefault7962-7916-12-1.cnf.xml
152 1593 Aug 15 2019 12:53:52 +01:00 its/vrf1/XMLDefault7962-7916-12-2.cnf.xml
153 1462 Aug 15 2019 12:53:52 +01:00 its/vrf1/XMLDefault7962-7916-24-1.cnf.xml
154 1593 Aug 15 2019 12:53:52 +01:00 its/vrf1/XMLDefault7962-7916-24-2.cnf.xml
155 1300 Aug 15 2019 12:53:52 +01:00 its/vrf1/XMLDefault7962.cnf.xml
156 1462 Aug 15 2019 12:53:54 +01:00 its/vrf1/XMLDefault7965-7914-1.cnf.xml
157 1593 Aug 15 2019 12:53:54 +01:00 its/vrf1/XMLDefault7965-7914-2.cnf.xml
158 1462 Aug 15 2019 12:53:54 +01:00 its/vrf1/XMLDefault7965-7915-12-1.cnf.xml
159 1593 Aug 15 2019 12:53:54 +01:00 its/vrf1/XMLDefault7965-7915-12-2.cnf.xml
160 1462 Aug 15 2019 12:53:54 +01:00 its/vrf1/XMLDefault7965-7915-24-1.cnf.xml
161 1593 Aug 15 2019 12:53:56 +01:00 its/vrf1/XMLDefault7965-7915-24-2.cnf.xml
162 1462 Aug 15 2019 12:53:56 +01:00 its/vrf1/XMLDefault7965-7916-12-1.cnf.xml
163 1593 Aug 15 2019 12:53:56 +01:00 its/vrf1/XMLDefault7965-7916-12-2.cnf.xml
164 1462 Aug 15 2019 12:53:56 +01:00 its/vrf1/XMLDefault7965-7916-24-1.cnf.xml
165 1593 Aug 15 2019 12:53:56 +01:00 its/vrf1/XMLDefault7965-7916-24-2.cnf.xml
166 1300 Aug 15 2019 12:53:58 +01:00 its/vrf1/XMLDefault7965.cnf.xml
167 1462 Aug 15 2019 12:53:58 +01:00 its/vrf1/XMLDefault7970-7914-1.cnf.xml
168 1593 Aug 15 2019 12:53:58 +01:00 its/vrf1/XMLDefault7970-7914-2.cnf.xml
169 1462 Aug 15 2019 12:53:58 +01:00 its/vrf1/XMLDefault7970-7915-12-1.cnf.xml
170 1593 Aug 15 2019 12:54:00 +01:00 its/vrf1/XMLDefault7970-7915-12-2.cnf.xml
171 1462 Aug 15 2019 12:54:00 +01:00 its/vrf1/XMLDefault7970-7915-24-1.cnf.xml
172 1593 Aug 15 2019 12:54:00 +01:00 its/vrf1/XMLDefault7970-7915-24-2.cnf.xml
173 1462 Aug 15 2019 12:54:00 +01:00 its/vrf1/XMLDefault7970-7916-12-1.cnf.xml
174 1593 Aug 15 2019 12:54:02 +01:00 its/vrf1/XMLDefault7970-7916-12-2.cnf.xml
175 1462 Aug 15 2019 12:54:02 +01:00 its/vrf1/XMLDefault7970-7916-24-1.cnf.xml
176 1593 Aug 15 2019 12:54:02 +01:00 its/vrf1/XMLDefault7970-7916-24-2.cnf.xml
177 1300 Aug 15 2019 12:54:02 +01:00 its/vrf1/XMLDefault7970.cnf.xml
178 1462 Aug 15 2019 12:54:02 +01:00 its/vrf1/XMLDefault7971-7914-1.cnf.xml
179 1593 Aug 15 2019 12:54:02 +01:00 its/vrf1/XMLDefault7971-7914-2.cnf.xml
180 1462 Aug 15 2019 12:54:04 +01:00 its/vrf1/XMLDefault7971-7915-12-1.cnf.xml
181 1593 Aug 15 2019 12:54:04 +01:00 its/vrf1/XMLDefault7971-7915-12-2.cnf.xml
182 1462 Aug 15 2019 12:54:04 +01:00 its/vrf1/XMLDefault7971-7915-24-1.cnf.xml
183 1593 Aug 15 2019 12:54:04 +01:00 its/vrf1/XMLDefault7971-7915-24-2.cnf.xml
184 1462 Aug 15 2019 12:54:04 +01:00 its/vrf1/XMLDefault7971-7916-12-1.cnf.xml
185 1593 Aug 15 2019 12:54:04 +01:00 its/vrf1/XMLDefault7971-7916-12-2.cnf.xml
186 1462 Aug 15 2019 12:54:06 +01:00 its/vrf1/XMLDefault7971-7916-24-1.cnf.xml
187 1593 Aug 15 2019 12:54:06 +01:00 its/vrf1/XMLDefault7971-7916-24-2.cnf.xml
188 1300 Aug 15 2019 12:54:06 +01:00 its/vrf1/XMLDefault7971.cnf.xml
189 1462 Aug 15 2019 12:54:06 +01:00 its/vrf1/XMLDefault7975-7914-1.cnf.xml
190 1593 Aug 15 2019 12:54:06 +01:00 its/vrf1/XMLDefault7975-7914-2.cnf.xml
191 1462 Aug 15 2019 12:54:06 +01:00 its/vrf1/XMLDefault7975-7915-12-1.cnf.xml
192 1593 Aug 15 2019 12:54:08 +01:00 its/vrf1/XMLDefault7975-7915-12-2.cnf.xml
193 1462 Aug 15 2019 12:54:08 +01:00 its/vrf1/XMLDefault7975-7915-24-1.cnf.xml
194 1593 Aug 15 2019 12:54:08 +01:00 its/vrf1/XMLDefault7975-7915-24-2.cnf.xml
195 1462 Aug 15 2019 12:54:08 +01:00 its/vrf1/XMLDefault7975-7916-12-1.cnf.xml
196 1593 Aug 15 2019 12:54:08 +01:00 its/vrf1/XMLDefault7975-7916-12-2.cnf.xml
197 1462 Aug 15 2019 12:54:08 +01:00 its/vrf1/XMLDefault7975-7916-24-1.cnf.xml
198 1593 Aug 15 2019 12:54:10 +01:00 its/vrf1/XMLDefault7975-7916-24-2.cnf.xml
199 1300 Aug 15 2019 12:54:10 +01:00 its/vrf1/XMLDefault7975.cnf.xml
200 1300 Aug 15 2019 12:54:10 +01:00 its/vrf1/XMLDefault7985.cnf.xml
201 1264 Aug 15 2019 12:54:10 +01:00 its/vrf1/XMLDefaultCIPC.cnf.xml
202 107 Aug 15 2019 12:53:16 +01:00 its/SEPDEFAULT.cnf
203 1152 Aug 15 2019 12:53:16 +01:00 its/united_kingdom_7960-tones.xml
204 19750 Aug 15 2019 12:53:16 +01:00 its/united_states_7960-dictionary.xml
205 8777 Aug 15 2019 12:53:18 +01:00 its/united_states_7960-font.xml
206 1313 Aug 15 2019 12:53:18 +01:00 its/united_states_7960-kate.xml
207 903 Aug 15 2019 12:53:18 +01:00 its/united_states_7960-tones.xml
208 2740 Aug 15 2019 12:53:18 +01:00 its/united_states_SCCP-dictionary.xml
209 13166 Oct 14 2011 11:34:32 +01:00 test.txt
210 499 Mar 22 2016 16:03:14 +00:00 copy
211 45308 Mar 22 2016 16:03:22 +00:00 BOOT69xx.0-0-0-14.zz.sgn
212 227828 Mar 22 2016 16:03:30 +00:00 DSP69xx.12-4-122-99.131025.zz.sgn
213 499 Mar 22 2016 16:03:36 +00:00 SCCP69xx.9-4-1-3SR2.loads
214 2872108 Mar 22 2016 16:03:46 +00:00 SCCP69xx.9-4-1-3SR2.zz.sgn
215 277521 Mar 30 2016 15:36:38 +01:00 crashinfo_20160330-131248-BST
216 120016 Aug 15 2019 13:56:34 +01:00 flash0
217 120016 Aug 15 2019 13:59:32 +01:00 rtl-sccp.jar
218 0 Aug 15 2019 14:04:46 +01:00 English_United_States
219 120016 Aug 15 2019 14:05:00 +01:00 English_United_States/rtl-sccp.jar
220 0 Aug 15 2019 14:05:28 +01:00 United_States
221 1413 Aug 15 2019 14:08:44 +01:00 United_States/g3-tones.xml
222 227828 Aug 15 2019 14:35:36 +01:00 DSP69xx.12-4-123-2.160119.zz.sgn
223 498 Aug 15 2019 14:35:44 +01:00 SCCP69xx.9-4-1-3SR3.loads
224 2875004 Aug 15 2019 14:40:36 +01:00 SCCP69xx.9-4-1-3SR3.zz.sgn
59482112 bytes available (200671232 bytes used)
Have manually tried to
no create cnf-files
create cnf-files
any help, appreciated
Dale
AbuAkif Riyaz
What is the IP Phone status message?
Riyaz
Rate Useful Post If it resolve your issue
