09-12-2012 09:56 AM - edited 03-16-2019 01:10 PM
6945 not registering to cme version 8,1. when i checked phone type list 6945 type is not listed .Which version support this phone.Please let me know.
Solved! Go to Solution.
09-12-2012 10:00 AM
CME 8.8 and onward.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme88spc.html
That means you can not use the 6945 with an ISR G1 router like 28xx and 38xx.
09-12-2012 10:01 AM
You can review that here:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
8.8 is the minimum for that model.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
09-12-2012 10:00 AM
CME 8.8 and onward.
09-12-2012 10:01 AM
java
09-12-2012 11:54 AM
Can i upgrade to version 9.0..?..Will it have any effect on licenses.
09-12-2012 11:56 AM
Wich router modeul do you have ?
09-12-2012 11:58 AM
2921 with ios 15.1(2)T5
09-12-2012 10:42 PM
You can update IOS to support CME 9.0. There is no licensing issue.
Thanks you for the nice rating and good luck!
