I realsise this topic has been covered before, but im unable to find a thread with this issue. Im trying to amend the LDAP filter in CM 7.1.3 using the AXL sql tool how ever when running the syntax below im receiving the following SOAP error, has anyone come across this before?
java -cp .\classes;.\lib\saaj-api.jar;.\lib\saaj-impl.jar;.\lib\mail.jar;.\lib\activation.jar;.\lib\jaxm-api.jar;.\lib\jaxm-runtime.jar;.\lib\xercesImpl.jar;.\lib\xml-apis.jar AxlSqlToolkit -username=CCMAdministrator -password=xxxxxxxx -host=xxxxxxxxx
Im getting the error below;
15-Sep-2010 11:39:53 com.sun.xml.internal.messaging.saaj.client.p2p.HttpSOAPConnection post
SEVERE: SAAJ0008: Bad Response; Not Found
com.sun.xml.internal.messaging.saaj.SOAPExceptionImpl: java.security.PrivilegedActionException: com.sun.xml.internal.messaging.saaj.SOAPExceptionI
mpl: Bad response: (404Not Found
at com.sun.xml.internal.messaging.saaj.client.p2p.HttpSOAPConnection.call(Unknown Source)
at AxlSqlToolkit.sendMessage(AxlSqlToolkit.java:138)
at AxlSqlToolkit.execute(AxlSqlToolkit.java:204)
at AxlSqlToolkit.main(AxlSqlToolkit.java:244)
Caused by: java.security.PrivilegedActionException: com.sun.xml.internal.messaging.saaj.SOAPExceptionImpl: Bad response: (404Not Found
at java.security.AccessController.doPrivileged(Native Method)
... 4 more
Caused by: com.sun.xml.internal.messaging.saaj.SOAPExceptionImpl: Bad response: (404Not Found
at com.sun.xml.internal.messaging.saaj.client.p2p.HttpSOAPConnection.post(Unknown Source)
at com.sun.xml.internal.messaging.saaj.client.p2p.HttpSOAPConnection$PriviledgedPost.run(Unknown Source)
... 5 more
Any help is greatly appreciated
