7821 SIP Phones
GWaldbin
We have few 7821 SIP phones which suddenly started having problems...these phones will ring continuously  but no one is calling!!! They also lose dial tone!!! Once you reset (power cycle) the phone, they work fine. Has anyone come across same symptoms? Any fixes? Thanks
6 Replies 6
Jaime Valencia
CME? CUCM? version? FW version?
java
if this helps, please rate
sorry...CUCM ver 9.1
FW version?
java
sip78xx.11-0-1-11
I'll see if there are any bugs, do you see something on the screen for this calls??
java
it seems like happening on 7800 model of SIP phones. Currently, I do not have accurate info on the display but these phones have shared lines. Also, when these symptoms occur, phone is registered in call manager (like a normal) phone but user told us it 'dead'!!! I am assuming they are saying there is no dial tone.
