04-20-2018 02:50 AM - edited 03-17-2019 12:40 PM
i cannot register conferencing station 7832 on CUCM 10.5.2 , i have a provisioning status failed on the web portal . please, can some one help with this issue a, it's doesn't work even by manually forcing the provisioning on the phone.
Solved! Go to Solution.
04-20-2018 07:55 AM
You bought a phone meant to be used with 3rd party PBX, not with CUCM, that's the problem.
04-20-2018 08:11 AM
That's correct, you got the 3PCC (3rd party call control) model
04-20-2018 06:29 AM
What is the exact CUCM release? and have you installed the required DevPack?
04-20-2018 07:49 AM
running in 10.5.2.15900-8 and i installed the last DEV PACK cmterm-devicepack10.5.2.17139-1
Software Version: | sip7832.11-0-1MPP-477.loads |
i have some errors in the traces for .cfg and .xml downloads from tftp . looks like the file is not found; i forced the provisioning manually for the files:
SIPDefault.cnf
SEPDefault.cnf
and
SEPXXXXXXXXXX.cnf.xml.sgn.
unfortunately i get the same errors
i share you the events from the phone
many thanks for your help
04-20-2018 07:55 AM
04-20-2018 08:08 AM
many thanks for your help ,
that means, there are two models, 7832 meant to be used with cucm and 7832-3pcc with third party ipbx ?
04-20-2018 08:11 AM
04-20-2018 08:14 AM
thank you very much
