7841 phones not displaying settings button
carl_townshend
Hi All
Hi all
We have recently installed a bunch of 7841 phones, however for some reason, logged in our out, they cannot access the admin settings on the applications softkey, I have the same phone and mine is fine.
The settings are enabled on the phone in cucm.
Any ideas ?
Try to check the box "Override Enterprise/Common Phone Profile Settings" in front of Settings Access [Enable it] and reset after saving it. Make sure to reset it and not restart.
Abhay
Kindly rate all helpful posts !!!
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
