03-18-2018 09:20 PM - edited 03-17-2019 12:26 PM
Seeking advice/understanding on whether the "shield" icon ought to appear when calls are made between two Cisco 7841 phones (both have their Security Profile set to SIP Authenticated profile).
This currently works with 7962 handsets. Online documentation does not specify whether 7841 supports this. Call Manager is running at 10.5.
Any assistance/advice is appreciated.
Solved! Go to Solution.
03-19-2018 09:02 PM
03-19-2018 02:21 AM
03-19-2018 07:48 PM
Hi Mohammed, many thanks for your reply. A colleague of mine believes it's not available on the 7841, and my testing also shows this is the case.
Just trying to see if anyone can confirm it's available (as it's not clearly documented anywhere).
03-19-2018 09:02 PM
03-19-2018 09:22 PM
Hi Aeby,
Thank you kindly for your detailed response. It appears as though the 7800 range doesn't support it, and hence why I'm unable to get it to work.
Thanks once again,
Fonda
