7906 and plantronics m12
gerard van rij
Dear all,
I have found a plantronics m12 headset which I want to use with my 7906. Is there a way answer a telephone call without lifting the horn?
regards,
Gerard
Rob Huffman
Hi Gerard,
Because the 7906G does not have built-in headset capabilities (no headset amplifier or headset button) the handset must be off hook to connect the audio stream. Most people who use the setup with the M12- Amplifier Kit and chosen headset just leave the phone off hook during the business hours and use soft keys to End call or New call. Have you looked at using Cordless headset and handset lifter to accomplish what you are looking for funtionally? The cost $$ is only a little more. Have a look at the Plantronics CS50 Cordless headset with lifter kit;
http://www.plantronics.com/canada/en_US/products/cat29880043/cat29880043/prod5210004
Hope this helps!
Rob
Rob Huffman
Hi Gerard,
Hope this helps!
Rob
Dear Rob,
but if I unhook the telephone, I cann't recieve telephone calls... and it is waiting for you to dial a number...
regards,
gerard
edit: fixed needed to "Disable Speakerphone"
thanks
