08-05-2008 11:07 AM - edited 03-15-2019 12:25 PM
Is this correct 7914 config
ephone 6
no multicast-moh
device-security-mode none
mac-address 001D.A219.F23B
ephone-template 1
username "vm880925"
type 7961 addon 1 7914
button 1:25 2:26 7:93 8:94 9:97 10:98 11:95 12:96 13:91 14:92 15:89 16:90 17:87 1
Is there something I am missing or doing wrong?
This is a CME set-up
08-05-2008 12:13 PM
Looks ok, what i have seen is that you need to hardcode the 7914 load under telephony service and create cnf-files
08-05-2008 12:19 PM
I have this but it is not working the way I thought it was suppose to.
ephone-6 Mac:001D.A219.F23B TCP socket:[15] activeLine:1 REGISTERED in SCCP ver 9 and Server in ver 5
mediaActive:1 offhook:1 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:9
IP:10.180.60.116 52050 7961 sub=3 keepalive 36 max_line 20
Phone reports 6 Available Lines
button 1: dn 25 number 880925 CH1 CONNECTED CH2 IDLE mwi
button 2: dn 26 number 880926 CH1 IDLE CH2 IDLE
button 7: dn 93 number 880993 CH1 IDLE CH2 IDLE mwi shared
button 8: dn 94 number 880994 CH1 IDLE CH2 IDLE shared
button 9: dn 97 number 880997 CH1 CONNECTED CH2 IDLE mwi shared
button 10: dn 98 number 880998 CH1 IDLE CH2 IDLE shared
button 11: dn 95 number 880995 CH1 IDLE CH2 IDLE shared
button 12: dn 96 number 880996 CH1 IDLE CH2 IDLE shared
button 13: dn 91 number 880991 CH1 IDLE CH2 IDLE mwi shared
button 14: dn 92 number 880992 CH1 IDLE CH2 IDLE shared
button 15: dn 89 number 880989 CH1 CONNECTED CH2 IDLE shared
button 16: dn 90 number 880990 CH1 IDLE CH2 IDLE shared
button 17: dn 87 number 880987 CH1 IDLE CH2 IDLE shared
button 18: dn 88 number 880988 CH1 IDLE CH2 IDLE shared
button 19: dn 51 number 880951 CH1 IDLE CH2 IDLE shared
button 20: dn 53 number 880953 CH1 IDLE CH2 IDLE shared
Active Call on DN 25 chan 1 :880925 10.180.60.116 17714 to 10.180.60.1 2000 via 10.180.60.116
G711Ulaw64k 160 bytes no vad
Tx Pkts 24230 bytes 4167560 Rx Pkts 24229 bytes 4167388 Lost 0
Jitter 1 Latency 28 callingDn -1 calledDn -1 (media path callID 436514 srcCallID 436515)
Username: vm880925
telephony-service
load 7960-7940 P0030702T023
load 7914 S00103020003
load 7931 SCCP31.8-2-1S
load 7941 SCCP41.8-0-4SR2S
load 7961 SCCP41.8-0-4SR2S
ephone 1
no multicast-moh
mac-address 001D.A219.EDD1
ephone-template 1
username "vm880901"
speed-dial 14 880915 label "Paging"
button 1o1,2,3,4,5 2x1 3x1 4x1
button 5x1 6:6 7:93 8:94
button 9:97 10:98 11:95 12:96
button 13:91 14:92 15:89 16:90
button 17:87 18:88 19:51 20:53
ephone 6
no multicast-moh
ephone-template 1
username "vm880925"
08-05-2008 12:20 PM
what the guy on site is telling me is the display does not support what is configured.
button 1 on the 7914 will show an 8 a space 983, not the 880993 that is on the dn name
ephone-dn 93 dual-line
number 880993
description Suzanne Rodruguez
name Suzanne Rodruguez
call-forward busy 880910
call-forward noan 880910 timeout 30
translation-profile incoming translations
