7925G "DHCP Timeout" error when attempting to connect.
Dwayne Phills
I have the following configured for Cisco IP 7925G Phones
- Call Manager CUCM 6.1.3
- Cisco Wireless Controller  2504  ----  WLAN configured for  WPA+WPA2 with PSK
- Cisco Wireless IP Phone  7925G  WLAN configured correctly
- DHCP is Windows Server 2008 R2 with Option 150 on the DHCP Scope plus Gateway, DNS , etc
The Cisco IP Phone 7925G is seems to connect to the WLAN correctly, but it can not get the DHCP IP assigment , it is stuck with Configuring IP and then DHCP Timeout . I have tested it , i can connect manually to through the WLAN and get a DHCP IP assigment via other devices.
Any assistance would be greatly appreciated.
Dwayne Phills
I figured it out. I was trying to run one of the vlans in DHCP mode. It ended up messing with my other vlans. Once I removed it, I was good to go.
Sent from Cisco Technical Support Android App
Hello Dwayne,
I am expriencing a similar issue, but could you please clarify your answer? What do you mean by "trying to run one of the vlans in DHCP mode"?
where is that setting? All my vlan have a dhcp scope associated.
tks.
