07-18-2011 09:03 AM - edited 03-16-2019 06:00 AM
Trying to go to http://phone-ip/CGI/Screenshot to pull a screenshot of one of my 7925Gs for documentation purposes.
I get the login, use the associated login, but only get a blank screen. I view the page source and it's blank too.
Any idea why?
Kinda bummed about this.
Using CUCM 8.5 and firmware CP7925G-1.3.4SR2.LOADS
Ven
Solved! Go to Solution.
07-18-2011 01:22 PM
I just tried this on the same firmware and it works fine on CUCM 7.1.5. However 8.5.1 did not work on my first try I got the same result as you. When you try and access /GCI/Screenshot do you see a host not found on the display of your phone? If so change the enterprise parameters for the authentication URL from a hostname to IP address for the non-secure URL and then reset the phone. Yours should now work as mine does.
07-18-2011 01:22 PM
07-18-2011 02:02 PM
That fixed it. Thank you.
Ven
