IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5956 Views
  • 14 replies
I have linked servers set up and I am able to successfully report off of the CVP Reporting servers.  I would also like to be able to use a similar process to provide custom reporting from Call manager 7.1(3).  Is it possible to set up a linked server...
Hello,I have a Cisco UC540 on which are registred Cisco IP Phones. I configured a sip account to test SIP phones on UC, this is sip configuration :voice register global mode cme source-address 192.168.10.10 port 5060 max-dn 20 max-pool 20 authenticat...
Hi Team,I have a Cisco 7911G IP Phone and i want to install it on Cisco Call Manager Version 3.2.Please let know whether it will support or not.I have seen in the document that it supports only on Cisco CallManager version 3.3(5) SR1 or later. Let me...
lalit by Level 1
  • 430 Views
  • 3 replies
The 9951 has 5 buttons on each side of the display. The left hand five I can configure using the normal phone button templates, so that's not a problem.But can I configure the five on the right hand side ? They seem to be change function depending on...
