11-12-2015 07:28 AM - edited 03-17-2019 04:53 AM
all,
In the last week or so my 7937 is doing a restart in the middle of a call. No sure why and no changes has been me.
up to now I change the interface:
switchport access vlan xx
switchport voice vlan xx
So I removed the switch access vlan xx....
now it happen again with a VP on a call.
11-12-2015 07:57 AM
Try a different switchport, change the connecting cable, and if the issue persists then you need to get a packet capture while reproducing the issue to actually see what is going wrong.
The 7937 firmware and cucm versions are also needed to check for any known issues.
Manish
03-16-2016 12:59 AM
Check if there is any flap in the switch-port on the phone, keep the phone connected with a PC for a wireshark capture to track the issue. Here is the document to collect captures from the back of the phone ( with CUCM )
https://supportforums.cisco.com/document/44741/collecting-packet-capture-cisco-ip-phone
If you are using phone with CME, then you can enable web access using following discussion:
https://supportforums.cisco.com/discussion/11293876/enable-web-access-cme-ip-phones
~Amit
