05-14-2013 03:45 PM - edited 03-16-2019 05:18 PM
Hi everybody
CUCM----SW-----R1
phone1, phone2
Above R1 is dhcp server, and NTP time source. CUCM 7 is also running tftp.
I have two 7940 phones attached to sw . Both phones have firmware PC03A300
How can i specify firmware PC03A300 in configuration file on tftp server running on CUCM? ( The goal is to avoid any firmware updates as I do not have access to latest firmware)
This is my first time messing with CUCM. So far no smoke : )
thanks and have a great day.
Solved! Go to Solution.
05-14-2013 04:16 PM
Not sure why you don't want the phone to upgrade the firmware, but in the configuration-page of the phone in CUCM you can specify the exact firmware version that you want the phone to grab/keep. If this is the same as the FW on your phone already, it won't get upgraded. If you leave this field empty, the FW will become the default that comes with your version of CUCM.
Gert
http://www.cisco.com/go/pdihelpdesk
Please rate helpful posts
05-14-2013 04:16 PM
Gert
05-14-2013 06:12 PM
Thanks Gert.
I do not have access to the latest FW. I am just implementing a simple home lab to study for CCNA V.
thanks
05-14-2013 07:06 PM
When you install CUCM the FW that comes with this version gets automatically installed - or are you using CUCM Express ?
Gert
