7941 +7962 Won't Boot - Bricked?
88pockets
I am just getting into learning cisco and i bought two phones and upon trying to reset them to factory defaults I seemingly broke them, but I still think they are recoverable. the first command 123456789*0# put the in an upgrade loop and the second 3491672850.# has them both with a blank screen.
I am trying to tftp the files over and the 7962 shows up on the dchp server tab of tftpd64
and here is what the log shows
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 88:90:8D:72:C1:76 [18/08 11:18:31.214]
Previously allocated address 192.168.3.32 acked [18/08 11:18:31.214]
Connection received from 192.168.3.32 on port 49763 [18/08 11:19:04.983]
Read request for file <term62.default.loads>. Mode octet [18/08 11:19:04.983]
Using local port 60584 [18/08 11:19:04.983]
<term62.default.loads>: sent 2 blks, 662 bytes in 0 s. 0 blk resent [18/08 11:19:04.984]
Connection received from 192.168.3.32 on port 52742 [18/08 11:19:40.083]
Read request for file <term62.default.loads>. Mode octet [18/08 11:19:40.083]
Using local port 49627 [18/08 11:19:40.083]
<term62.default.loads>: sent 2 blks, 662 bytes in 0 s. 0 blk resent [18/08 11:19:40.084]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 88:90:8D:72:C1:76 [18/08 11:22:28.852]
Previously allocated address 192.168.3.32 acked [18/08 11:22:28.852]
The phone is plugged into a 3560g 10/100 POe switch and the firewall/router is pfsense.
Note: I do not have CCUM, looking to get it somehow, but alas no support contract with cisco.
I feel I am close and I have tried older firmware SIP and SCCP.. I have the firmware files from ciscos support page and an xml to point in the right direction ((i think) any help would be much appreciated.
88pockets
I figured it out, it was a matter of having the right version, not to old not too new, which for both phones was SCCP41.9-3-1SR1-1S
