7962G IP Phone - sending or receiving SMS/MMS ?
garrettgrobler
Would like to know if it is possible for the 7962G IP Phone to send or receive SMS/MMS/Text/Video/Pictures?
2 Accepted Solutions
Jaime Valencia
I don't think there's any chance for video/pictures as the phone display does not provide a good quality for either, but you might be able to create your own custom services for the other, you would need to build all the infrastructure and programming on your own, as that is not an out of the box feature.
java
if this helps, please rate
as stated video/pictures is not possible since this phone is not video enabled, refer the below doc for features supported on this device.
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-7962g/product_data_sheet0900aecd8069bd41.html
for text you have to configure a URL service, but there are some limitations on it. you can refer the below link once.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/all_models/xsi/6_0/english/programming/guide/XSIbook.pdf
Jaime Valencia
java
