10-10-2013 11:01 AM - edited 03-16-2019 07:50 PM
Community,
I have a customer who is experiencing what appears to be a cosmetic error on their 7965s. When deploying endpoints into the field they have found that if they hard code the speed/duplex to 100/Full on the PC port of the phone they get a "Port Configuration Error". The funny thing is that the PC appears to function normally at 100 Full. When I change the endpoint to auto-negotiate from CUCM the error goes away.
Has anyone ever run into this?
Endpoint: 7965
Protocol: SIP
Load: SIP45.9-3-1SR2-1S
10-10-2013 11:05 AM
What is the switch port set to?
10-10-2013 11:09 AM
I'm not sure. The guys working on the network portion of the install have departed. The issue I'm running into is on the PC port of the phone connected to a daisy-chained PC.
10-10-2013 11:17 AM
No worries, how about the actual switch port on the phone? Are both the PC and SW ports set to Auto or 100 Full? I would still be curious about what the network port on the switch is set to as well. I am running 7965G's in both SCCP and SIP form and no matter how I have the ports set and cannot recreate. I am also running 9.3.1sr2 firmware on both.
