8800 Key Expansion Module
j.ayres
Can anyone advise when orderability for the 8800 Series Key Expansion Module (CP-BEKEM=) is going to be turned on?
Justin
keglass
Level 7
Level 7
Justin,
If you are a Cisco Partner with access to the Cisco Partner Community, then I recommend you post this question to that space for more feedback and for access to partner-related resources.
Collaboration
Kelli Glass
Moderator for Cisco Customer Communities
cralvara
Level 6
Level 6
Hello J.ayres,
The 8800 Series Key Expansion Module (CP-BEKEM=) is already orderable at CCW.
Best Regards,
Cristina Alvarado
Global Virtual Engineering - Partner Help
