8800 Phone load matrix question
DD4
Are there any issues with upgrading my phone load from sip88xx.10-3-1-20 directly to sip88xx.12-1-1SR1-4? My current version of CM is 10.5.2.13900-12.
I tried to look for the matrix for the new phone load and couldn't find my answer.
Thanks for your help.
I've checked and don't see any suggestions indicating to upgrade to a previous load prior to going to the new one (12-1-1SR1).  I'm hoping that someone has actually done this upgrade.
Thanks for your reply though.
Updated phone load directly to 12-1-1SR1-4. No issues have been reported.
Jaime Valencia
Review the README and RN for the FW you want to use, if there is a need for a middle step, it will be mentioned there.
java
if this helps, please rate
