8831 Wired Mic Question
iancarder
Hi All,
Does anyone here have the wired mic kit for the 8831 conference phone?  It's CP-MIC-WIRED-S.  What is the cable length on the Microphones?  I'm having a hard time finding anything that mentions it.
-Ian
Rob Huffman
Hi Ian,
The cable length on each "wired mic" is 7 feet;
Wired microphones
These microphones extend the operational range of the Cisco Unified IP Conference Phone 8831 with even coverage around the periphery of the device with 7 feet of additional reach.
From;
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-8800-series/data_sheet_c78-726887.html
Cheers!
Rob
Anybody know the best/easiest way to extend these cables? 7 feet is practically nothing, especially if you want to do any sort of cable management.
cordevil95.
I recently had the same issue - looking for the cable extension for  the CP 8831 wired mic, I couldn't find the cable extension kit to extend the 7 feet that comes with the kit.
then it occurs to me i was looking at the problem but not at the solution.   We should  use the wireless mic  kit instead.  : )
/hairul
