8841 failing to connect to Asterisk
ABlock14956
Greetings all. I'm experienced with devops but new to the telephony / SIP world. I am trying to connect an 8841 phone to a vanilla FreePBX install running on a Raspberry Pi.
Configuration
  • Phone is a CUCM 8841 (CP-8841-W)
  • Phone firmware is sip88xx.10-3-1-20
  • Asterisk 16.6.1, FreePBX 15.0.16.22
  • pjsip with UDP and TCP transports enabled on port 5060, TLS on 5061
  • All devices are on a local subnet
Issue description
I set the TFTP server address manually on the 8841, then spun up a TFTP server on the Pi to serve a sepmac.cnf.xml file (attached below) gleaned from the various ones floating around this forum. Most of the ones I tried did not work and resulted in an error entry in the phones status log, but I got one to work — and by "work" I mean that the phone acknowledges it without error.
I installed the Asterisk/FreePBX distro, and enabled TCP and UDP pjsip, both on port 5060. I created two SIP extensions and confirmed I was able to connect to them with Zoiper / Linphone and make calls back and forth.
However, I have not been able to get the phone to register. On the phone's status screen, it just keeps repeating:
[timestamp]
Error updating locale
[timestamp]
[timestamp]
VPN not configured
[timestamp]
SEPxxxxxxxxxxx.cnf.xml(TFTP)
...over and over.
Meanwhile, the Asterisk logs show the following:
[2020-09-12 23:16:41] ERROR[1185]: pjproject: <?>: 	sip_transport. Error processing 1262 bytes packet from UDP 192.168.19.187:5060 : PJSIP syntax error exception when parsing 'Request Line' header on line 1 col 1:
R?h?V????????8.19.189 SIP/2.0
Via: SIP/2.0/UDP 192.168.19.187:5060;branch=z9hG4bK0691a84a
From: "" <sip:@192.168.19.187>;tag=ac7e8a2bfaf900d4617722f7-46c21df8
To: <sip:192.168.19.189>
Call-ID: ac7e8a2b-faf900d4-0d22d180-744c4a6f@192.168.19.187
Date: Sat, 12 Sep 2020 20:43:42 GMT
CSeq: 1000 REFER
User-Agent: Cisco-CP8841/10.3.1
Expires: 10
Max-Forwards: 70
Contact: <sip:@192.168.19.187:5060;transport=udp>
Require: norefersub
Referred-By: "" <sip:@192.168.19.187>
Refer-To: cid:3cad1cf0@192.168.19.187
Content-Id: <3cad1cf0@192.168.19.187>
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE
Content-Length: 509
Content-Type: application/x-cisco-alarm+xml
Content-Disposition: session;handling=required
<?xml version="1.0" encoding="UTF-8"?>
<x-cisco-alarm>
<Alarm Name="DeviceTLInfo">
<ParameterList>
<String name="DeviceName">SEPAC7E8A2BFAF9</String>
<String name="IPv4Address">192.168.19.187</String>
<String name="IPv6Address"></String>
<String name="CTL_Signature">Not Installed</String>
<String name="CTL_TFTP_Server">N/A</String>
<String name="ITL_Signature">Not Installed</String>
<String name="ITL_TFTP_Server">N/A</String>
<String name="StatusCode">6</String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
-- end of packet.
...over and over.
At this point I am completely out of ideas, having tried various things that I found in this forum (changing <transportLayerProtocol>, etc.) without success. Any pointers or suggestions would be very much appreciated.
Thanks!
ABlock14956
Okay, looking at the Asterisk log suggested to me that the issue was the garbled junk at the beginning of the "Request Line" request. I thought that might be related to UDP so I changed the transportLayerProtocol to TCP (1), and I can now connect to Asterisk.
I am now having two new issues:
1. I can dial into the 8841's extension from a Linphone client. The 8841 rings and I can answer it with the Answer softkey, which puts the call on speakerphone. However, if I pick up the handset I can neither hear nor talk.
2. I cannot call the Linphone extension (102) from the 8841. When I dial that number I get the following error in the Asterisk log:
[2020-09-13 01:00:21] NOTICE[16847]: res_pjsip/pjsip_distributor.c:676 log_failed_request:
Request 'INVITE' from '"Anonymous" <sip:Anonymous@192.168.19.189>' failed for '192.168.19.187:50640'
(callid: ac7e8a2b-faf90010-415e8743-07315e62@192.168.19.187) - Failed to authenticate
As before, any suggestion much appreciated!
Changing <transportLayerProtocol> to 1 worked for me too (after enabling TCP in PJSIP). Thank you!
ABlock14956
Okay, well: the answer to #1 was "plug the handset in correctly".
As for #2, I enabled Anonymous Inbound SIP calls and Allow SIP Guests in the Asterisk settings, which allowed me to make calls to other extensions. But seems like I should configure authentication from the 8841 if that is possible in the xml file.
