8841 ip phone - 4 way cluster navigation button back light is not going off
We have a 8841 Cisco IP phone, on it display light idle time is configured. It is turning off as expected, however 4 way navigation button turns on as soon as display light goes off.  On phone configuration, no setting available for navigation light? is there any way to turn it off? Please suggest.
Jaime Valencia
No, there is no way to change that.
java
if this helps, please rate
Thank you.
Aeby Vinod
Level 3
Level 3
There is an enhancement request opened for this feature:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvb90559/?referring_site=bugquickviewredir
If you really think that this feature that is essential please contact your accounts manager so that they can push for the inclusion of this feature in future firmware releases by filing for a product enhancement request.
Please rate if you find this helpful.
Aeby
Aeby
thamano
Same issue for 8851. Our users do not need or want a night light while the device is dimmed, in fact they want it completely dark.
