02-03-2016 05:08 PM - edited 03-17-2019 05:44 AM
I've searched high and low on the internet and cisco, and not finding answer for what these console messages on a 8865 IP Phone console log mean prior to the DEAUTH. I've stumbled across some hits on linux and android boards but not finding the reason code numbers or etype numbers yet.
This is on a 8865 IP phone with 11.0.1 firmware.
What is wlanmgr(309)-wm_event_callback etype:5 ? There are a few dozen of these messages in log prior to the DEAUTH.
(a few dozen of this event_callback etype:5 )
5293 DEB Feb 03 09:40:31.480374 wlanmgr(309)-wm_event_callback etype: 5
5294 DEB Feb 03 09:40:33.485933 wlanmgr(309)-wm_event_callback etype: 5
5295 DEB Feb 03 09:40:35.491503 wlanmgr(309)-wm_event_callback etype: 5
5296 DEB Feb 03 09:40:37.497099 wlanmgr(309)-wm_event_callback etype: 5
5297 DEB Feb 03 09:40:39.502631 wlanmgr(309)-wm_event_callback etype: 5
5298 DEB Feb 03 09:40:41.508159 wlanmgr(309)-wm_event_callback etype: 5
5299 INF Feb 03 09:40:41.956920 kernel: [109357.851043] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
5300 WRN Feb 03 09:40:41.956963 kernel: [109357.851074] link down if wlan0 may call cfg80211_disconnected. event : 16, reason=1 - what is this?
5301 DEB Feb 03 09:40:41.958509 wlanmgr(309)-[process_event]: received nl80211 event: NL80211_CMD_DISCONNECT
5302 DEB Feb 03 09:40:41.958548 wlanmgr(309)-[process_event]: disconnected (by AP)
5303 DEB Feb 03 09:40:41.958695 wpa_supplicant[753]: nl80211: Drv Event 48 (NL80211_CMD_DISCONNECT) received for wlan0
5304 DEB Feb 03 09:40:41.958719 wpa_supplicant[753]: nl80211: Disconnect event
5305 DEB Feb 03 09:40:41.958740 wpa_supplicant[753]: wlan0: Event DEAUTH (12) received -- what is 12?
Erick
02-03-2016 10:57 PM
Can the phone connect to an SSID with open authentication?
02-04-2022 05:19 AM
I'm having the same issue with an 8861 desk phone. The phone connects and works fine but every now and then the phone will unregistered and we have to reset all settings on the phone and reconfigure the wireless settings.
051 WRN Feb 04 01:18:10.055935 (6297-6298) wpa_supplicant-WPA: EAPOL-Key M1 is received at COMPLETED STATE.So we have to pend M1 packet 1052 DEB Feb 04 01:18:11.060256 (6297-6298) wpa_supplicant-nl80211: Drv Event 48 (NL80211_CMD_DISCONNECT) received for wlan0 1053 WRN Feb 04 01:18:11.060793 kernel: [8694029.867072] wl_process_host_event: Link event 6, flags 0, status 0 1054 DEB Feb 04 01:18:11.060315 (6297-6298) wpa_supplicant-nl80211: Disconnect event 1055 DEB Feb 04 01:18:11.060983 (6297-6298) wpa_supplicant-wlan0: Event DEAUTH (12) received 1056 DEB Feb 04 01:18:11.061015 (6297-6298) wpa_supplicant-wlan0: Deauthentication notification 1057 DEB Feb 04 01:18:11.061033 (6297-6298) wpa_supplicant-wlan0: * reason 3 1058 DEB Feb 04 01:18:11.061048 (6297-6298) wpa_supplicant-Deauthentication frame IE(s) - hexdump(len=0): [NULL] 1059 NOT Feb 04 01:18:11.061069 (6297-6298) wpa_supplicant-wlan0: CTRL-EVENT-DISCONNECTED bssid=90:4c:81:85:29:81 reason=3 1060 WRN Feb 04 01:18:11.061575 kernel: [8694029.867085] MACEVENT: WLC_E_DEAUTH_IND, MAC 90:4c:81:85:29:81, reason 3 1061 WRN Feb 04 01:18:11.061613 kernel: [8694029.867604] wl_process_host_event: Link event 16, flags 0, status 0 1062 WRN Feb 04 01:18:11.061631 kernel: [8694029.867612] MACEVENT: WLC_E_LINK DOWN
