8941 8945 static ip address "invalid ip address"
Any idea ?
It works in dhcp mode
9 Replies 9
julienf28
I'm having similar issues...did you come up with a resolution?
J
You cannot leave the default gateway field empty.
I actually populated it with an IP address and it is still giving me IP error
Julien Franche
Systems Administrator / Ottawa
Tél./Tel. 613-233-1781 x50124
gowlings.com <>
Actually, I had the DNS field empty. This was the cause. J
Julien Franche
gowlings.com <>
Good news! Happy to hear it is working.
cmluck888
I'm sorry, I recently met this problem and how you solve
We used dhcp, but the other guy says it's related to the dns, you should try to add a dns
Let me know if it works. The other point is that my 8941 is the first one, I would try to upgrade.
Philippe
Hi Team,
We are also having the same issue. We use Static IP in our network and no matter what ip we give it says Invalid IP address, it is not letting me to enter even DNS or Gateway IP.
Initially phone didn't download firmware from CUCM 8.6 so we did it manually to the same firmware version which CUCM is having it. Phone firmware Version is 9.1.2-SR
By default we received phones with 9.3.2-11 firmware.
Any suggestion would be highly appreciated.
Thanks in advance
MAC
Regards MAC
Check phone default Gateway
