11-04-2011 04:07 AM - edited 03-16-2019 07:52 AM
Any idea ?
It works in dhcp mode
11-30-2011 09:48 AM
I'm having similar issues...did you come up with a resolution?
J
11-30-2011 10:01 AM
You cannot leave the default gateway field empty.
11-30-2011 10:20 AM
I actually populated it with an IP address and it is still giving me IP error
Julien Franche
Systems Administrator / Ottawa
Tél./Tel. 613-233-1781 x50124
gowlings.com <>>
11-30-2011 10:22 AM
Actually, I had the DNS field empty. This was the cause. J
Julien Franche
gowlings.com <>>
11-30-2011 10:39 AM
Good news! Happy to hear it is working.
10-11-2012 05:13 AM
I'm sorry, I recently met this problem and how you solve
10-11-2012 05:23 AM
We used dhcp, but the other guy says it's related to the dns, you should try to add a dns
Let me know if it works. The other point is that my 8941 is the first one, I would try to upgrade.
Philippe
05-31-2013 02:11 AM
Hi Team,
We are also having the same issue. We use Static IP in our network and no matter what ip we give it says Invalid IP address, it is not letting me to enter even DNS or Gateway IP.
Initially phone didn't download firmware from CUCM 8.6 so we did it manually to the same firmware version which CUCM is having it. Phone firmware Version is 9.1.2-SR
By default we received phones with 9.3.2-11 firmware.
Any suggestion would be highly appreciated.
Thanks in advance
MAC
04-05-2020 08:57 AM
Check phone default Gateway
