8945 missing functionality
bilgecetin
Visitor
I have recently done a new installation wtih 8945 and it was my first experience with these phones and what surprised me is that some of the functionalities that I had with 79xx series are not there anymore. For example I cannot get the join softkey appear on the display anymore even tough it is defined in the doftkey template.
And during a call if I go to directory, I cannot initiate a transfer of conference thorugh a direcotyr entry.
Is it me missing soemthing or are these functions not available on 894x series?
5 Replies 5
Gordon Ross
Level 11
Level 11
Softkey templates don't work on 89xx/99xx series phones
Instead, you have to define a Feature Control Policy  (CCMAdmin->Device->Device Settings->Feature Control Policy), then apply it to your phones.
I don't know why Cisco have done this. I've vented my unhappiness about this to my account manager & SE.
GTG
Please rate all helpful posts.
Just to add to Gordon's reply, unfortunately there are several softkeys that are not supported on the 8941's/45's (including the Join softkey).  The feature control policy is supported on the 8961's, but not the 41's or 45's.  See the link below:
The Cisco Unified IP Phones 8941 and 8945 do not support all the softkeys that are configurable in Softkey Template Configuration on Cisco Unified CM Administration. Cisco  Unified Communications Manager allows you to enable or disable some  softkeys in the control policy configuration settings, but the Cisco  Unified IP Phones 8941 and 8945 do not support feature control policy  configuration settings.
Table 5-2
lists the features, softkeys that can be configured on a softkey template, and note whether it is supported on the Cisco Unified IP Phones 8941 and 8945.
Table 5-2     Configurable Softkeys
Feature
Configurable Softkeys in the Softkey Template Configuration
Supported as a softkey on Cisco Unified IP Phone 8941 and 8945
Notes
Answer
Answer (Answer)
Yes
Barge
Barge (Barge)
No
Call Back
Call Back (CallBack)
Yes
Call Forward All
Forward All (cfwdAll)
Yes
Phone displays Fwd ALL or Fwd Off.
Call Park
Call Park (Park)
Yes
Call Pickup
Pick Up (Pickup)
Yes
Conference
Conference (Confrn)
Yes
Conference is a dedicated button.
Only exists on video call.
Conference List
Conference List (ConfList)
Yes
Phone displays Detail.
Divert
Immediate Divert (iDivert)
Yes
Phone displays Divert.
Do Not Disturb
Toggle Do Not Disturb (DND)
Yes
Configure Do Not Disturb as a programmable line button.
End Call
End Call (EndCall)
Yes
Phone displays Cancel if the call is not answered.
Group Pickup
Group Pick UP (GPickUp)
Yes
Hold
Hold (Hold)
No
Hold is a dedicated button.
Hunt Group
HLog (HLog)
Yes
Configure Hunt Group as a programmable feature button.
Join
Join (Join)
No
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/8941_8945/8_5/english/admin_guide/6921usr.html#wp1031287
HTH,
Chris
I'm late to the party here but I thought I'd kick this post instead of starting a  new one.  Can anyone confirm the above table is still accurate for CUCM 9.1(1) w/ 8945 (SIP)?  I'm not getting the Join softkey as expected and can't find the updated version of the 8.5 doc that's linked.
This is the latest one
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cuipph/8941_8945/9_0/english/admin_guide/P415_BK_C1A45FBB_00_admin-guide-8941-8945_chapter_0101.html#P415_RF_SABA1ECB_00
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thanks, java.  just what I needed.  Looks like the naming went from 'CM' to 'Cisco Unified Communications Manager' which threw Google off 😄
