9951 with CKEM at CME
astrohmeier
I have a CME 9.1. Connected to the CME I have a 9951 with CKEM.
At the voice register pool I added the CKEM with "Type 9951 addon 1 CKEM" but the CKEM do not register. Do I have to do more than the type command?
thanks for your help
Achim
7 Replies 7
Stefan Walter
i have the same problem. Also a CME 9.1. At the voice register pool 1 I added the expansion module with the same command but I have a 8961 Phone Model.
I got an error message from the phone, that the LKEM has been detected but is disabled by the administrator. How can I activate the LKEM ? There are no documentation about this.
Stefan
I know this is very old, but I have this issue.  Anyone have any details on how to do this or enable I think the USB ports?
Getting this error: LKEM has been detected but diabled.
Todd
islam.kamal
Level 10
Level 10
Kindly be informed that CKEM
as  blf-speed-dial,number and  speed-dial commands, in voice register pool configuration mode
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmebasic.html#wp1273718.
. Kindly you have to put into your consideration the power consumption .If  the Cisco Unified IP Color Key Expansion Module is connected to a Cisco  Unified IP Phone that uses 802.3AT power, a local power supply is not  required. If the phone uses 802.3AF power, you must connect a power cube  to it for it to supply power for all connected key expansion modules.  If the phone is already locally powered by a power cube, no additional  power cube is required when installing the key expansion module to it.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps10655/ps10676/data_sheet_c78-565427.html
Thank you
please rate if this will help
after I execute the command create profile --> in the voice register global mode.
The CKEM is working fine.
Thanks for help,
Stefan
were you able to configure BLF with KEM on 9951, 9971 or 8961 ?
From Cisco website:
You can program feature key buttons on the Cisco Unified IP Color Key Expansion Module as a directory number, line key, or speed-dial key. The buttons are illuminated, and when configured as a directory number or shared-line keys they allow for easy identification of call state. This capability provides features that are similar to those of typical direct station selection/busy lamp field (DSS/BLF) modules but are not intended to be directly comparable to those of traditional DSS/BLF modules. The Cisco Unified IP Color Key Expansion Module is neither an operator nor an attendant console. Its primary function is to provide the Cisco Unified IP Phone 9971, 9951, and 8961 models with additional keys for features such as speed dial or directory numbers. The illuminated buttons make it easy to determine line status, making the Cisco Unified IP Color Key Expansion Module an ideal call-coverage tool.
Yes at the end it works. I do not know any more what I have done at the end but it worked.
Achim
I have added the last three entries to the voice registered pool, but they do show in the
Cisco IP Phone 8800 Key Expansion Module
Model CP-BEKEM...am I missing an step here?
 busy-trigger-per-button 6
 id mac 5006.AB08.D73C
 session-transport tcp
 type 8851 addon 1 CKEM 2 CKEM
 number 1 dn 1
 template 1
 dtmf-relay rtp-nte sip-notify
 username user1 password cisco
 codec g711ulaw
 paging-dn 100
 blf-speed-dial 1 2530 label "Alan P-2530"
 blf-speed-dial 2 2580 label "Aziza-2580"
 blf-speed-dial 3 2150 label "Bonnie-2150"
 blf-speed-dial 4 1050 label "Cindy-1050"
 blf-speed-dial 5 1311 label "Conf Lobby-1311"
 blf-speed-dial 6 1312 label "Conf main-1312"
 blf-speed-dial 7 2200 label "David-2200"
 blf-speed-dial 8 2890 label "Eric-2890"
 blf-speed-dial 9 1301 label "Guest1-1301"
 blf-speed-dial 10 1302 label "Guest2-1302"
 blf-speed-dial 11 1209 label "Hannah-1209"
 blf-speed-dial 12 1020 label "Jackie-1020"
 blf-speed-dial 13 2840 label "Janis-2840"
 blf-speed-dial 14 2330 label "Jeff-2330"
 blf-speed-dial 15 2260 label "John C-2260"
 blf-speed-dial 16 2930 label "John K-2930"
 blf-speed-dial 17 1226 label "Joe-1226"
 blf-speed-dial 18 1230 label "Justin-1230"
 blf-speed-dial 19 2160 label "Katie-2160"
 blf-speed-dial 20 1010 label "Kenneth-1010"
 blf-speed-dial 21 2520 label "Kevin-2520"
 blf-speed-dial 22 2070 label "Kirby-2070"
 blf-speed-dial 23 2970 label "Kyle-2970"
 blf-speed-dial 24 2960 label "Leon-2960"
 blf-speed-dial 25 2690 label "Loren-2690"
 blf-speed-dial 26 1207 label "Mark-1207"
 blf-speed-dial 27 2500 label "Michelle-2500"
 blf-speed-dial 28 3080 label "Mike-3080"
 blf-speed-dial 29 1204 label "Mikhal-1204"
 blf-speed-dial 30 2060 label "Mitchell-2060"
 blf-speed-dial 31 1290 label "Samantha-1290"
 blf-speed-dial 32 2180 label "Sarah-2180"
 blf-speed-dial 33 2140 label "Stephanie-2140"
 blf-speed-dial 34 2025 label "Stephen-2025"
 blf-speed-dial 35 2460 label "Teresa-2460"
 blf-speed-dial 36 2380 label "Timothy-2380"
 blf-speed-dial 37 1224 label "Tony-1224"
 blf-speed-dial 38 2800 label "Tonya-2800"
 blf-speed-dial 39 1310 label "Training-1310"
 blf-speed-dial 40 1030 label "Wanda-1030"
 blf-speed-dial 41 1040 label "Wendi-1040"
 blf-speed-dial 42 2010 label "Tiffany-2010"
 blf-speed-dial 43 2290 label "James-2290"
 blf-speed-dial 44 2880 label "PJ-2290"
