9971 weather and calculator applications
Anas Abueideh
Level 9
Level 9
Hi All,
I have CCM 8.6 and 9971 phones with firmware 9971.9-1-1SR1. I am trying to configure weather and calculator applications without any success.
I download the jad and jar files from cisco website. I upload the files to the tftp and create a URL service but it didn't work. I don't know if we need external webserver or not
Can anyone help with this ? thanks in advance
giftonabel
For both MIDlets (in the form of a JAD file and a JAR file) to operate properly, port 80 communication must be unblocked between IP Phones and the Internet.
Note: Refer to the steps mentioned in the "Midlet Installation and Configuration Guide.pdf" available while downlading the apps file.
HTH,
Gifton Abel.
giftonabel
HTH,
Gifton Abel.
Anas Abueideh
Level 9
Level 9
yoy are right regarding the guide. I found you need a web server to run these files.
Anas
Sent from Cisco Technical Support Android App
Frank Hohenadel
where have you found the files on the website?
Regards, Frank
Files are here: http://www.cisco.com/c/en/us/products/unified-communications/ipPhone_thankyou.html
Mansoor
