a B-ACD problem....
oracat777
Hi all,
now I have a problem with the simple B-ACD AA script, I do the following configuration on the router, then is works(when I call the phone number from pstn, the AA script will answer the call with the prompt music, and then I can press "0" or 20600 to connect to the operator or dial the Ext. directly), but it will fail to work after about one week (with no configuration changed, and it had happened two times), if I call it from PSTN when it fail to work, the AA script will answer the call with the prompt music as normal, and i can dial the Ext. number directly as normal(including the operator number), but when I press "0" for connecting to operator, it will have no response(if I press "#" or just waiting after pressing "0", it will be aways silent and no timeout prompt and no connection).
I do not known how to solve the problem and there are some configuration and debug in the router, I hope to have some suggestion about this.
Thanks in advance!!!
=======configuration============
application
service AA flash:its-CISCO.2.0.1.0.tcl
  param operator 20600
  paramspace english language en
  paramspace english index 1
  paramspace english location flash:
  paramspace english prefix en
voice-port 0/0/0
supervisory disconnect dualtone mid-call
secondary dialtone
cptone CN
timeouts initial 0
timeouts interdigit 3
timeouts call-disconnect 5
timeouts wait-release 5
caller-id enable
voice-port 0/0/1
secondary dialtone
cptone CN
timeouts initial 0
caller-id enable
voice-port 0/0/2
secondary dialtone
cptone CN
timeouts initial 0
caller-id enable
voice-port 0/0/3
secondary dialtone
cptone CN
timeouts initial 0
caller-id enable
dial-peer voice 1 pots
preference 1
service aa
destination-pattern 9T
direct-inward-dial
port 0/0/0
dial-peer voice 2 pots
preference 2
service aa
direct-inward-dial
port 0/0/1
dial-peer voice 3 pots
preference 3
service aa
direct-inward-dial
port 0/0/2
dial-peer voice 4 pots
preference 4
service aa
direct-inward-dial
port 0/0/3
================debug when is fail to work============================
BJ_GM_R2921#debug voice application script
voip application script debugging is on
BJ_GM_R2921#
BJ_GM_R2921#
BJ_GM_R2921#
BJ_GM_R2921#
Sep 20 08:46:11.987: //1873//TCL :/tcl_PutsObjCmd: proc act_Setup
proc init_perCallvars
ANI 13521231023
DNIS
No DNIS
BJ_GM_R2921#
================debug when I input the B-ACD script reload command and it can work again============================
BJ_GM_R2921#call application voice load AA
BJ_GM_R2921#
BJ_GM_R2921#
BJ_GM_R2921#
BJ_GM_R2921#
Sep 20 08:54:14.499: //-1//HIFS:/hifs_ifs_cb: hifs ifs file read succeeded. size=6589, url=flash:its-CISCO.2.0.1.0.tcl
Sep 20 08:54:14.499: //-1//HIFS:/hifs_free_idata: hifs_free_idata: 0x2A143F90
Sep 20 08:54:14.499: //-1//HIFS:/hifs_hold_idata: hifs_hold_idata: 0x2A143F90
BJ_GM_R2921#
BJ_GM_R2921#
Sep 20 08:54:26.467: //1890//TCL :/tcl_PutsObjCmd: proc act_Setup
ANI 13521231023
DNIS
No DNIS
Sep 20 08:54:29.203: //1890//TCL :/tcl_PutsObjCmd:
proc act_GotDest
Call  got event cd_006 collecting destination
BJ_GM_R2921#
BJ_GM_R2921#
BJ_GM_R2921#
BJ_GM_R2921#
Sep 20 08:55:28.799: %FILESYS-5-CF: System CompactFlash 0 removed
Sep 20 08:55:42.707: //1894//TCL :/tcl_PutsObjCmd: proc act_Setup
ANI 13521231023
DNIS
No DNIS
BJ_GM_R2921#
Sep 20 08:55:48.187: //1894//TCL :/tcl_PutsObjCmd:
proc act_GotDest
Sep 20 08:56:17.499: %FILESYS-5-CF: System CompactFlash 0 inserted
BJ_GM_R2921#
BJ_GM_R2921#
I do not known is it necessary to config these command on the router but I do not config it on the router(and it can work well without these command)
incoming called-number  .
direct-inward-dial
service AA
thanks
Yu.
0 Replies 0
