IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6166 Views
  • 14 replies
Hi all,I'm experiencing problem with IP Phone 9951 registration to CUCM version 8.0.3. The phone can't registered to the CUCM eventhough I have specify the MAC Address on CUCM.The phone displaying "Phone not registered", and i have check on the phone...
hendi1995 by Level 1
  • 6146 Views
  • 13 replies
Resolved! Bulk UDP Update
Hi,We have over 3000 User Device Profiles that need the User Hold MOH Audio Source field changed back to <none>  on CUCM 7.13Can't seem to find an easy to do a bulk update for UDPs - is this not possible or am i missing something obvious?Thanks
rchaseling by Level 4
  • 2255 Views
  • 15 replies
Dear friends,We are trying to upgrade a cluster of two CUCM 6.0.1(1b) servers, to CUCM 8.6(1a). These new servers will run on vmware esx which will be installed on Cisco UCS Server. We are stuck on the restore phase. The procedure will have the follo...
Arber_123 by Level 1
  • 2893 Views
  • 3 replies
hello,I have Call Manager 4.1.  I have Cisco 3825 router with 12.4 IOS and a DHCP set up on it.I have (2) questions:1) how many phones can be supported like this ?2) the I have (2) DHCP pools set up. one with 172.24.106.0 255.255.255.254, and a secon...
galaga by Level 1
  • 1976 Views
  • 18 replies
Whenever someone dials a person locally, the receiving phone shows the same number ringing on both the primary line and the on hold line. It looks a though the calling phone is calling the same number twice simutaniously. The dialed phone goes to voi...
wesleyj84 by Level 1
  • 355 Views
  • 1 replies
Hey all.I changed a 7912 from sccp to sip.  It was reported this phone worked 100% before the software change...Now..  Only the softkeys, up and down arrow, volume up (the volume down key does not work), and headet off hook appear to respond when you...
rbblue234 by Level 1
  • 624 Views
  • 3 replies
Hi AllI would like to have a UC520 automatically reboot (by applying some command on configuration) after every 2 or month continues running and set a time and date frame.because we have few customers with UC500, UC520, after 3 months they cant make ...
