09-22-2015 01:41 AM - edited 03-17-2019 04:22 AM
Hi Friends
I have a question about Route Pattern number exclude.
Now 9.222XXXXXX is to my city
9.[^2][^2][^2] XXXXXX is to other city
but if i dial 9233666666 , I can not make the call
so i try 9.[^222]XXXXXX, I still can not make the call
But I do have such a demand,Who can tell me how to design the route pattern.
Thanks & Best Regards
Donke xu
Solved! Go to Solution.
09-26-2015 03:17 AM
You can create translation pattern in PT_LD to match 98.222 and 98.224 and block them. Translation pattern will take precedence over route-pattern
09-26-2015 05:44 AM
Hi Mohammed,
I guess he wants to do it in the most optimum way (aka least configuration).
09-22-2015 01:57 AM
Because when you dial 9233666666, it doesn't match either of the route pattern.
Can you please let us know the area codes where you want to route the call so that we can assist you better.
There are plenty of reference documents on Cisco.com which I suggest you to refer.
09-22-2015 03:48 AM
I suggest you start with Dialplan SRND to understand how call routing works. Then let us know what you are trying to achieve.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab10/collab10/dialplan.html
09-22-2015 06:20 AM
Assuming you have the same you posted, there is a blank space between the last [^2] and the X which is not supported,
And FYI, whatever you put inside [] is not a literal chain, that is a group of numbers that are interpreted independently.
You would need to look into your dial plan to see what you have, and configure accordingly, you can use DNA to see what you're doing.
09-25-2015 07:22 PM
Hi Jaime Valencia
I want to know What numbers can match 9.8[222]!,9.8[222]! It does not seem to be able to exclude 98222XXXXXXX。
What consecutive three digit representatives in the []。
09-25-2015 07:59 PM
Just curious, what is that exactly you want to achieve, as there could be many ways to achieve the same results?
Could you please elaborate this a little more?
09-25-2015 08:24 PM
I want to desgin a route pattern for Domestic long distance ,my city code is 222,so the route pattern for Local call is 98.222XXX-XX-XX,I want to design 98.[^222]XXX-XX-XX for Domestic long distance but This appears to be a wrong design.I can't Exclude continuous 222 in the Route Pattern.
Thank you for your attention
Best Regards
Donke xu
09-25-2015 08:50 PM
Ok, so what will happen if you let the users dial 98.222-XXX-XX-XX ? Why would you want the calls to be blocked to 98.222-XXX-XX-XX?
I mean if the user dials 98.222-XXX-XX-XX or 98.223-XXX-XX-XX, either case the call gets handed to the Telco and telco will route both the calls, what is the issue here, I am wondering?
09-25-2015 10:48 PM
Yes Wilson, you are right ,But now the question is about Competence.
CSS | RoutePattern | Partition | Remark | |
CSS_LO | 98.222-XXX-XX-XX | PT_LO | LO(Local) | |
CSS_LD | 98.???-XXX-XX-XX | PT_LD | Except98.222&98.224) | LD(Long Distance) |
CSS_ILD | 98.224! | PT_ILD | ILD(International Long Distance) |
224 is ILD Access Code ,Offered by Telecommunications company
Now I have Three Phone
PhoneA(CSS_LO) Only local call privileges
PhoneB(CSS_LD) Only long-distance call privileges
PhoneC(CSS_ILD) Only international long-distance call privileges
How to design my LD Route Pattern can achieve this.I try many method but i still can't separate LD Call Route from 98.XXX-XXX-XX-XX.
Thanks&Best Regards
Donke xu
09-26-2015 03:17 AM
09-26-2015 05:44 AM
Hi Mohammed,
09-26-2015 09:42 AM
Hi Mohammed al Baqari
This seems a good idea but if I had a phoneD it has both long-distance call privileges and international long-distance call privileges,You know Translation Pattern is earlier than Route Pattern, because my translation pattern block 98.224! PhoneD can't make a international long-distance call.
Special thanks for you help many times.
Donke xu
09-27-2015 02:56 AM
In this case, put the translation pattern in separate partition and make sure that PhoneB CSS has both partitions.
For PhoneD CSS it should contain both partitions for LD and INT but not the PT for translation pattern.
09-27-2015 06:53 PM
Yes Of course, this is no problem ,I think if other friends encounter this problem and this will the best solution
Thanks&Best Regards
Donke xu
09-26-2015 05:43 AM
Hi Donke,
I think understand your issue, you want to achieve the results where, Local Calls, should be able to dial 98.222-XXX-XX-XX and not any Long Distance which are 98.224-XXX-XX-XX and 98.223-XXX-XX-XX and you want to achieve the results with minimal configuration.
I think there is something missing in the configuration or the phones are able to get a match on the Route Pattern for Long Distance (Local Calls phones that you wanted to implement).
I will request you to try this:
1. Create a Route Pattern in Partition, with 98.[^2][^2][^2]-XXX-XX-XX and allow it be routed via the GW
2. Assign, a phone a test CSS, and let that CSS contain ONLY the above Route Pattern, and see if it meets the desired results.
More over, if you are able to dial Long Distance, then please share us the DNA output from the phone / DN and it will help us clarify, where the logic needs to be changed.
