Add Names to 7915 expansion module (side car)?
annheatherton
How do you add names for the phone lines on the side car? Our phone guy has been trying for days. Thanks.
Amit Kumar
It should take Label field , assigned to ephone-dn, which is getting assigned to button on side car. Considering an CUCME deployment:
say:
ephone-dn <tag> dual
name Test
number 1001
Label Test-1001
When this DN is assigned to button on side car, then line should display, "Test-1001"
Hope that helps.
Surender Singh
Login to CUCM Admin page-->Phone-->find your phone which you have 7915 attached to-->on phone configuration page locate Association Information--> On the left hand side select the Speed Dial (SD) line you want to modify-->put the extension and label information.
Make sure that you have made a phone button template that has all the ports for the expansion module on it as well and apply that template to the phone.
