Adding background image on 7945 phone
Burney Rogers
I have requet to add a background image on a 7945 phone. I have seven background images already, is there a limit. I want to add this image without losing the original seven background images. Can creat a List.xml with the new image files thum and png in the call manager or do I have to add the new image to the List.xml that the orignal seven exists.
Chris Deren
I dont know if there is a limit, but I am pretty sure it still siginificantly higher than 7. Simply add the additional ones to the TFTP servers and update the xml file.
Chris
add the background images to the tftp server in the respective directory for 7945
you can only have one list.xml file in that directory - so add the other background images to the current list.xml
