Adding extensions to hunt group via CLI
jason
I currently have a hunt group that has been configured through the cisco CLI. I want to add some extensions, but am not having much luck. Is there anyone that can help me out with the commands?
Here is the current configuration
voice hunt-group 2 parallel
final 299
list 250,251,252
timeout 28
pilot 512
My goal is to add two extensions to that list. I read that you cannot add one extension at a time, so do I need to remove all extensions and then add a new list?
Any help is appreciated.
Jason
16 Replies 16
I'm new to cisco. The past two days are my first ever trying to look into this, so I wasn't sure how to manage it. I went in through telnet and it looks like that may have worked. I cannot test it being that I'm not in the office at this time, but it shows up correct under the "show tech-support" link.
I will confirm tomorrow if this worked.
Here is what it shows: (looks promising)
final 299
list 250,251,252,253,215
timeout 28
pilot 512
Jason,
Continue with telnet or ssh for administration. Less confusing and better results. If you need further help let us know
Remember to rate helpful posts clicking the stars below.
Kind regards,
- Adrian.
