Adding ringtones to non-primary DN
blumcapital
I am trying to add custom ringtones to use with the non-primary DN on some phones. The primary line is using the "Ringtone.xml" list on the TFTP server (and listing about 20 ringtones by friendly name), however, the other DNs on phones with more than one only list "Ring 1", "Ring 2", etc., through "Ring 8".
How can I add custom ringtones that will show up on that shorter list?
Oh, CCM 4.1(3) btw.
Thanks.
blumcapital
Never mind. Figured this out.
Hi BC,
I didn't think that this was possible?? If you found a method to do this maybe you could share your results. It would be greatly appreciated :)
Rob
Sorry for the delay in responding.
The process is the same as it is to add a ringtone to the primary DN, only instead of editing the file "ringlist.xml", you edit "distinctiveringlist.xml".
Instructions located here: http://www.cisco.com/en/US/customer/docs/voice_ip_comm/cucm/admin/4_1_3/ccmfeat/fsrings.html.
