after adding users how to add devices, aka jabber, android and iphone profiles in bulk
jtaveras914
i have added 90+ users to cucm 10.5 with ext. now i need to add jabber, android and iphone call profiles, can someone point me on the right direction. i have used Jaime Valencias tuts but stuck at this. every one adds phones but i dont need them.
thanks
Jaime Valencia
Configure one of each device you need, and then use BAT to export them, then use it as a template for the remaining devices.
java
if this helps, please rate
thats what i did but some still give me errors
examples are
BOT
CFS
TAB
TCT
I get errors for BOT and TAB when using bulk, the others worked ok
MAC Address/Device Name Error Code Error Description
TABATWYMAN DEVICE :: Error : 491 The specified name has invalid characters or is not formatted correctly for this device type.Valid characters include [a-zA-Z0-9._-]{1,50}
cucm 10.5.x
Take a look at these bugs
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCui75002
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuv58344
java
thanks for the quick responses but ....
the example does not have over 15 characters and its all cap letters.
template is TCP-UK
Errors:
Insert Phones in /common/bps/csvfiles/phones/insert/specific/ad-TAB.csv
Failure Details :
TABADISALVO DEVICE :: Error : 491 The specified name has invalid characters or is not formatted correctly for this device type.Valid characters include [a-zA-Z0-9._-]{1,50}
TABAAHEE DEVICE :: Error : 491 The specified name has invalid characters or is not formatted correctly for this device type.Valid characters include [a-zA-Z0-9._-]{1,50}
These do not meet the requirements for failure.
Anything else?
