AIM-CUE Integrated Service Module Replacement
johnsnave1
I have a customer who needs to replace a faulty AIM-CUE Integrated Service Module - part number: 800-20063-04.
Can you advise if this module is still available? If not, is there a replacement that will work in a 2801 router?
Many thanks, John.
Rajan
Hi John,
AIM-CUE & its replacement module AIM2-CUE-K9 module is EOL. So it seems like you need to go with the replacement of that which is :
ISM-SRE-300-K9
http://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/eol_c51-655336.html
Rajan
Rajan
Hi John,
ISM-SRE-300-K9
Rajan
johnsnave1
Hi Rajan, ok many thanks. I don't think the ISM-SRE-300-K9 is compat with the customer's 2801 but perhaps we can convice them to buy a 29xx.
Cheers.
