05-01-2017 03:27 PM - edited 03-17-2019 10:12 AM
I have a lab set up with the below physical configuration. I’m trying to route a call out the VG to my CME Router via a VWIC ports to simulate a PRI connection to Telco. For some reason I’m not matching my outgoing Dial-peer on the VG. I see in the logs the call making it to the VG Router, but there it says no match. If I test 3333000 I get no match. Anybody have thoughts on what I can be missing?
The VWIC shows connected, but the dial-peer shows down on the VG. On the CME Router the VWIC is connected and Dial-peer shows up. I get a busy signal calling either way (SIP Phone -> VG -> CME -> SCCP Phone OR SCCP Phone -> CME -> VG -> SIP Phone)
Physical Config:
CUCM -> VG (2801 ISR) -> VWIC -> VWIC -> CME (2801 ISR) -> SCCP Phone
Numbers in test:
Calling Number: 1112002
Called Number: 3333000
CUCM: 172.16.1.5
VG Side:
Dial peers:
dial-peer voice 1 voip
translation-profile incoming inbound
session protocol sipv2
session transport tcp
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3000 pots
trunkgroup PRI-GRP
description 3333000 Numbers to CME RTR via PRI Line
destination-pattern 3333000
forward-digits all
dial-peer voice 1000 voip
description 1000 and 2000 DID
preference 1
destination-pattern [1,2]0..
session target ipv4:172.16.1.5
voice-class codec 1
dtmf-relay rtp-nte
no vad
Misc Configs:
trunk group PRI-GRP
hunt-scheme sequential both down
controller T1 0/1/0
cablelength long 0db
pri-group timeslots 1-24
description ** PRI VOICE CONNECTION TO S0/2/0 PSTN-RTR **
interface Serial0/1/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
no isdn outgoing display-ie
trunk-group PRI-GRP
no cdp enable
Show dial-peer voice summary:
ak-lab-vg1#show dial-peer voice summary
dial-peer hunt 0
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT KEEPALIVE
1 voip up up 0 syst
3000 pots up up 3333000 0 down trunkgroup PRI-VG1
1000 voip up up [1,2]0.. 1 syst ipv4:172.16.1.5
ak-lab-vg1#
ak-lab-vg1#
Show dialplan number examples:
ak-lab-vg1#show dialplan number 3333000
Macro Exp.: 3333000
No match, result=-1
ak-lab-vg1#show dialplan number 1000 | inc tag
tag = 1000, destination-pattern = `[1,2]0..',
voice reg type = 0, corresponding tag = 0,
voice class perm tag = `'
ak-lab-vg1#
Show ISDN Status:
ak-lab-vg1#show isdn status
Global ISDN Switchtype = primary-ni
ISDN Serial0/1/0:23 interface
dsl 0, interface ISDN Switchtype = primary-ni
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 4
Total Allocated ISDN CCBs = 0
ak-lab-vg1#
Debugs:
ak-lab-vg1#
*May 1 12:32:35.931: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=3333000, Called Number=3333000, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=3333000
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
*May 1 12:32:35.931: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=3333000, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1
*May 1 12:32:35.931: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
*May 1 12:32:35.931: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=1112002, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Result=NO_MATCH(-1) After All Match Rules Attempt
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
*May 1 12:32:35.935: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*May 1 12:32:35.935: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*May 1 12:32:35.935: //-1/4D8191800000/DPM/dpAssociateIncomingPeerCore:
Calling Number=1112002, Called Number=3333000, Voice-Interface=0x0,
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1
*May 1 12:32:35.935: //-1/4D8191800000/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
*May 1 12:32:35.943: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=3333000, Peer Info Type=DIALPEER_INFO_SPEECH
*May 1 12:32:35.947: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*May 1 12:32:35.947: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=3333000, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
*May 1 12:32:35.947: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
*May 1 12:32:35.947: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*May 1 12:32:35.947: //-1/4D8191800000/DPM/dpMatchPeersCore:
*May 1 12:32:35.951: //-1/4D8191800000/DPM/dpMatchSafModulePlugin:
*May 1 12:32:35.951: //-1/4D8191800000/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
*May 1 12:32:35.951: //-1/4D8191800000/DPM/dpMatchPeersCore:
Result=NO_MATCH(-1)
*May 1 12:32:35.951: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*May 1 12:32:35.951: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*May 1 12:32:35.951: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
*May 1 12:32:35.951: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=3333000, Called Number=, Voice-Interface=0x0,
*May 1 12:32:35.955: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*May 1 12:32:35.955: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*May 1 12:32:35.955: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
*May 1 12:32:35.955: //-1/4D8191800000/DPM/dpMatchPeersCore:
*May 1 12:32:35.955: //-1/4D8191800000/DPM/dpMatchSafModulePlugin:
*May 1 12:32:35.955: //-1/4D8191800000/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
ak-lab-vg1#
ak-lab-vg1#un all
All possible debugging has been turned off
ak-lab-vg1#
CME Side:
cme2#show dial-peer voice summary
dial-peer hunt 0
AD PRE PASS OUT
1 voip up up 0 syst
3000 voip up up 30.. 1 syst ipv4:192.168.2.1
1000 pots up up 111[1,2].. 0 up trunkgroup PRI-GRP
20001 pots up up 3000$ 0 50/0/1
20002 pots up up 3001$ 0 50/0/2
cme2#show isdn status
ISDN Serial0/2/0:23 interface
******* Network side configuration *******
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
The Free Channel Mask: 0x8000FFFF
Number of L2 Discards = 0, L2 Session ID = 6
cme2#
Solved! Go to Solution.
05-02-2017 02:52 PM
The CCME gateway is saying the called number doesnt exist:
Looking at your config, I dont any pattern or ephone-dn that matched this number..
Called Party Number i = 0xC1, '3333000'
May 2 21:33:10.983: ISDN Se0/2/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x8087 Cause i = 0x8281 - Unallocated/unassigned number
05-01-2017 07:51 PM
Why are you using a Trunkgroup, on the CUCM side of your VG?
I would remove that for testing and just point your pots dial peer to destination 333000 to port 0/1/0:15 just to simplify things for starters
Please rate if useful
05-02-2017 07:43 AM
thank you....
I was about to change that and noticed that, in my "debugging", I was changing things and realized my trunk group created and trunkgroup in my dial-peer were different.. Made that update and still get a busy signal, but looks like I'm at least hitting my DP now......sheesh...:(
Updated DP:
ak-lab-vg1#show run | sec dial-peer voice 3000 pots
trunkgroup PRI-GRP
description 3000 Numbers to CME RTR via PRI Line
destination-pattern 3333...
forward-digits all
ak-lab-vg1#
Debug:
ak-lab-vg1#show dialplan number 3333000 | inc tag
tag = 3000, destination-pattern = `3333...',
ak-lab-vg1#
Calling number 1111000:
ak-lab-vg1#debug voice dialpeer inout
voip dialpeer inout debugging is on
ak-lab-vg1#
ak-lab-vg1#
*May 2 06:39:34.327: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
*May 2 06:39:34.327: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=3333000, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
*May 2 06:39:34.327: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=3000
*May 2 06:39:34.327: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=1111000, Called Number=, Voice-Interface=0x0,
*May 2 06:39:34.331: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*May 2 06:39:34.331: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*May 2 06:39:34.335: //-1/9C3A26000000/DPM/dpAssociateIncomingPeerCore:
Calling Number=1111000, Called Number=3333000, Voice-Interface=0x0,
*May 2 06:39:34.335: //-1/9C3A26000000/DPM/dpMatchSafModulePlugin:
*May 2 06:39:34.343: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*May 2 06:39:34.343: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=3333000, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
*May 2 06:39:34.343: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
*May 2 06:39:34.347: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*May 2 06:39:34.347: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*May 2 06:39:34.351: //-1/9C3A26000000/DPM/dpMatchPeersCore:
*May 2 06:39:34.351: //-1/9C3A26000000/DPM/dpMatchSafModulePlugin:
*May 2 06:39:34.351: //-1/9C3A26000000/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Result=SUCCESS(0)
*May 2 06:39:34.351: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*May 2 06:39:34.351: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*May 2 06:39:34.351: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
*May 2 06:39:34.351: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*May 2 06:39:34.355: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*May 2 06:39:34.355: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*May 2 06:39:34.355: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*May 2 06:39:34.355: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
*May 2 06:39:34.359: //-1/9C3A26000000/DPM/dpMatchPeersCore:
*May 2 06:39:34.359: //-1/9C3A26000000/DPM/dpMatchSafModulePlugin:
*May 2 06:39:34.359: //-1/9C3A26000000/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
ak-lab-vg1#
ak-lab-vg1#
ak-lab-vg1#un all
ak-lab-vg1#
ak-lab-vg1#
05-02-2017 01:31 PM
You need to look at the whole equation here
1. ISDN debugs
2. CCME debugs
1.show isdn status ( to see the status of your PRI)
2. debug isdn q931 ( to see your ISDN q931 logs) ( you may also run this on CCME side)
3. On CCME ( debug voip ccapi inout )--to see what happens when calls hit the gateway
4. debug ephone state ( to see what happens when the call is presented to the phone)
Attach log output along with sh run and we may be able to help much better
05-02-2017 02:22 PM
Thanx.. Please see attached..
I ran the ephone debug separate from the q931.
Both show channel 23 not available on the CME router... Which would make sense if I only have 16 there...
Not sure how to make that change... I changed the controller T1 0/1/0 on the VG to pri-group timeslots 1-16 but then the "Out Stat" on the show dial-peer voice summary changed to "down" So i put it back to 1-24...... and it's still down...:(
05-02-2017 02:22 PM
You can change your channel selection order..on your gateway add this
isdn bchan-number-order ascending
05-02-2017 02:42 PM
05-02-2017 02:52 PM
05-02-2017 03:18 PM
ah for cryin out loud...
thank you - i updated my ephone dn 1 to 3333000 and it work..... thank you for taking the time to educate me a bit...;(
I am now able to ring from my SIP Phone -> vg -> VWIC (PRI) -> VWIC (PRI) -> CME -> SCCP Phone
05-02-2017 12:32 PM
Why did you suggest 0/1/0:15 vs 0/1/0:23 for example?
Thank You
