02-01-2019 06:03 AM - edited 03-17-2019 02:03 PM
I'm training on Unified Communications and I got a 3845 for practice using CME, I've been trying to setup the AIM2-CUE-K9 module I got all the files and updated to the latest version possible for both, the router and the AIM Module.
When I try to setup the module it shows me that can't mount the sda, is there a way to run a diagnostic or try to reinstall from 0 or just the helper is my only option. I'm trying to figure out if I need to get a new module, if I'm using the wrong files. I do have a valid license (I have smart account) for the module but I haven't go to that point yet.
Router:
Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 15.1(4)M12a, RELEASE SOFTWARE (fc1)
Interfaces:
GigabitEthernet0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/1 192.168.1.239 YES NVRAM up up
Internal-Service-Module0/0 192.168.1.239 YES unset up up
Vlan1 unassigned YES unset up up
AIM2:
Router#service-module internal-Service-Module 0/0 status
Service Module is Cisco Internal-Service-Module0/0
Service Module supports session via TTY line 322
Service Module is waiting for registration message
Service Module heartbeat-reset is enabled
Service Module status is not available
Available Files for setup:
cue-installer.nmx.8.6.7
cue-vm-k9.nmx.8.6.7.pkg
cue-vm-installer-k9.nmx.8.6.7.prt1
cue-vm-langpack.nmx.8.6.7.pkg
cue-vm-full-k9.nmx.8.6.7.prt1
cue-vm-en_US-langpack.sme.8.6.12.prt1
cue-vm-es_MX-langpack.sme.8.6.12.prt1
timecardview.sme.8.6.12.prt1
Results from the Service Module:
Initializing memory. Please wait...
Memory initialization OK. Continue...
DDR Memory 0512 MB detected
Genuine Intel(R) processor 600MHz
BIOS AIMII 2.6, BIOS Build date: 10/16/2009
System now booting...
Authenticating boot loader....
Primary Boot Loader Authenticated - booting....
Please enter '***' to change boot configuration:
Loading disk:/bzImage ... Unable to load image
Unable to boot image
Attempt to use the helper:
INIT: version 2.86 booting
mounting proc fs ...
mounting sys fs ...
mounting /dev/shm tmpfs ...
kernel.sem = 1900 4000 32 100
vm.overcommit_memory = 1
vm.min_free_kbytes = 8192
Welcome to Cisco Service Engine
Setting the system time from hardware clock
********** rc.aesop ****************
Populating resource values from /etc/aim2_rsrc_file
Populating resource values from /etc/default_rsrc_file
Populating resource values from /etc/products/cue/default_rsrc_file
Populating resource values from /etc/products/cue/aim2_rsrc_file
/dev/sda: No such device or address
sfdisk: cannot open /dev/sda for reading
expr: syntax error
set: invalid parameters: /hw/platform/module/drive_capacity
Usage: set <path> <value> [<type>]
==> Management interface is eth0
IOS IP Address Registration complete.
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
192.168.1.0 * 255.255.255.0 U 0 0 0 eth0
default 192.168.1.239 0.0.0.0 UG 0 0 0 eth0
Size of buff is: 65536
65536 bytes written
Valid License file not found: Using default values
INIT: Entering runlevel: 2
********** rc.post_install ****************
Changing owners and file permissions.
INIT: Switching to runlevel: 4
INIT: Sending processes the TERM signal
STARTED: dwnldr_startup.sh
Welcome to Cisco Systems Service Engine Helper Software
Please select from the following
1 Install software
2 Reload module
3 Disk cleanup
4 Install License(s)
(Type '?' at any time for help)Choice: 3
WARNING::
WARNING:: This command will temporarily free up disk space by:
WARNING::
WARNING:: 1) Deleting log files and unnecessary system files.
WARNING:: 2) Compacting the Voicemail database.
WARNING::
Do you wish to run this command now (y,n)? y
Removing unnecessary files
touch: cannot touch `/mnt/var/log/messages.log': No such file or directory
touch: cannot touch `/mnt/var/log/install.log': No such file or directory
WARNING::
WARNING:: Unable to find relevant DB programs. Skipping DB compact.
WARNING::
/bin/disk_cleanup.sh: line 190: ((: <= 1024000 : syntax error: operand expected (error token is "<= 1024000 ")
/bin/disk_cleanup.sh: line 199: ((: <= 512000 && > 94 : syntax error: operand expected (error token is "<= 512000 && > 94 ")
umount: /mnt: not mounted
1 Install software
2 Reload module
3 Disk cleanup
Choice:
