11-15-2012 11:08 PM - edited 03-16-2019 02:13 PM
Currently Being Moderated
hi my guys i have a big problem
when i set service aa on dial-peer voice 1 pots my all outside calls go to busy and when i use no service on dial-peer it works correctly
my router config is:
Current configuration : 11867 bytes
version 12.4
service password-encryption
hostname Ru201.Padideh.net
boot-start-marker
boot system flash c2800nm-adventerprisek9_ivs-mz.124-24.T.bin
boot-end-marker
card type e1 0 1
logging message-counter syslog
enable secret 5 $1$2KQv$jnhcn/4qud040i60EknaF.
no aaa new-model
clock timezone ir 3 30
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
network-clock-select 2 E1 0/1/1
dot11 syslog
ip source-route
ip cef
no ip domain lookup
ip domain name Ru05.Padideh.net
no ipv6 cef
ntp server 10.17.104.1
ntp server 129.6.13.35
isdn switch-type primary-net5
voice-card 0
application
service aa flash:app-b-acd-aa-2.1.2.2.tcl
paramspace english index 1
param number-of-hunt-grps 2
param menu-timeout 6
param handoff-string aa
param dial-by-extension-option 5
paramspace english language en
param max-time-vm-retry 2
param max-extension-length 4
param aa-pilot 1054
paramspace english location flash:
param second-greeting-time 60
param welcome-prompt _bacd_welcome.au
param call-retry-timer 1
param max-time-call-retry 1
param service-name queue
service queue flash:app-b-acd-2.1.2.2.tcl
param queue-len 30
param aa-hunt1 1200
param queue-manager-debugs 1
param aa-hunt2 2100
username ARM password 7 155A08051729246D
username MKZ password 7 041159555F701E1D59484F
archive
log config
hidekeys
controller E1 0/1/0
pri-group timeslots 1-31
controller E1 0/1/1
class-map match-any Wifi-Guest
match any
policy-map Wifi-Guest
class Wifi-Guest
police 256000
interface Loopback38888
ip address 10.16.254.1 255.255.255.0
interface Tunnel201
ip address 10.17.255.18 255.255.255.252
interface GigabitEthernet0/0.240
encapsulation dot1Q 240
ip address 10.16.97.1 255.255.255.0
ip helper-address 10.17.104.11
ip nat inside
ip virtual-reassembly
interface GigabitEthernet0/0.250
encapsulation dot1Q 250
ip address 10.16.99.1 255.255.255.0
ip access-group Wifi-Guest in
ip nat inside
service-policy output Wifi-Guest
interface GigabitEthernet0/0.260
encapsulation dot1Q 260
ip address 10.16.100.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.270
encapsulation dot1Q 270
ip address 10.16.101.1 255.255.255.0
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/1/1:15
no ip address
encapsulation hdlc
no cdp enable
router eigrp 200
network 10.16.97.0 0.0.0.255
network 10.16.99.0 0.0.0.255
network 10.16.100.0 0.0.0.255
network 10.16.101.0 0.0.0.255
network 10.17.100.0 0.0.0.127
network 10.17.104.0 0.0.0.255
network 10.17.255.16 0.0.0.3
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 80.191.241.129
ip route 10.11.12.0 255.255.255.0 GigabitEthernet0/0.144
ip http server
no ip http secure-server
ip http path usbflash0:/GUI
ip nat inside source list 1 interface GigabitEthernet0/0.135 overload
ip nat inside source static tcp 10.17.104.5 3389 80.191.241.132 3389 extendable
ip access-list extended Wifi-Guest
permit tcp 10.16.99.0 0.0.0.255 host 10.17.104.11 eq domain
permit udp 10.16.99.0 0.0.0.255 host 10.17.104.11 eq domain
deny ip 10.16.99.0 0.0.0.255 10.0.0.0 0.255.255.255
permit ip any any
access-list 1 permit 10.16.99.0 0.0.0.255
access-list 1 permit 10.16.97.0 0.0.0.255
access-list 1 permit 10.17.104.0 0.0.0.255
route-map clients permit 10
match ip address 110
set ip next-hop 10.17.104.17
route-map clients permit 20
tftp-server usbflash0:/7906-7911/cvm11sccp.8-3-2-27.sbn alias cvm11sccp.8-3-2-27.sbn
tftp-server usbflash0:/7906-7911/jar11sccp.8-3-2-27.sbn alias jar11sccp.8-3-2-27.sbn
tftp-server usbflash0:/7906-7911/SCCP11.8-3-3S.loads alias SCCP11.8-3-3S.loads
tftp-server usbflash0:/7906-7911/term06.default.loads alias term06.default.loads
tftp-server usbflash0:/7931/apps31.8-3-2-27.sbn alias apps31.8-3-2-27.sbn
tftp-server usbflash0:/7931/cnu31.8-3-2-27.sbn alias cnu31.8-3-2-27.sbn
tftp-server usbflash0:/7931/cvm31sccp.8-3-2-27.sbn alias cvm31sccp.8-3-2-27.sbn
tftp-server usbflash0:/7931/dsp31.8-3-2-27.sbn alias dsp31.8-3-2-27.sbn
tftp-server usbflash0:/7931/jar31sccp.8-3-2-27.sbn alias jar31sccp.8-3-2-27.sbn
tftp-server usbflash0:/7931/SCCP31.8-3-3S.loads alias SCCP31.8-3-3S.loads
tftp-server usbflash0:/7931/term31.default.loads alias term31.default.loads
tftp-server flash:/apps75.8-3-2-27.sbn alias apps75.8-3-2-27.sbn
tftp-server flash:/cnu75.8-3-2-27.sbn alias cnu75.8-3-2-27.sbn
tftp-server flash:/cvm75sccp.8-3-2-27.sbn alias cvm75sccp.8-3-2-27.sbn
tftp-server flash:/dsp75.8-3-2-27.sbn alias dsp75.8-3-2-27.sbn
tftp-server flash:/jar75sccp.8-3-2-27.sbn alias jar75sccp.8-3-2-27.sbn
tftp-server flash:/SCCP75.8-3-3S.loads alias SCCP75.8-3-3S.loads
tftp-server flash:/term75.default.loads alias term75.default.loads
control-plane
voice-port 0/1/0:15
voice-port 0/1/1:15
mgcp fax t38 ecm
dial-peer voice 1100 voip
destination-pattern 11..
session protocol sipv2
session target ipv4:10.17.8.1
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 2100 voip
destination-pattern 21..
session target ipv4:10.17.40.1
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 3100 voip
destination-pattern 31..
session target ipv4:10.17.72.7
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 5100 voip
destination-pattern 51..
dial-peer voice 91 voip
destination-pattern 91
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 92 voip
destination-pattern 92
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 93 voip
destination-pattern 93
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 95 voip
destination-pattern 95
dial-peer voice 8 pots
service aa
incoming called-number 1054
port 0/1/1:15
gatekeeper
shutdown
telephony-service
max-ephones 30
max-dn 60
ip source-address 10.16.101.1 port 2000
system message PADIDEH.NET
load 7911 SCCP11.8-3-3S.loads
load 7931 SCCP31.8-3-3S.loads
load 7975 SCCP75.8-3-3S.loads
time-zone 33
time-format 24
date-format yy-mm-dd
max-conferences 8 gain -6
moh en_bacd_music_on_hold.au
multicast moh 239.1.1.1 port 2100
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1
and my debug massage is:
*Dec 16 04:45:20.523: //-1/127ABE148015/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=7662228
cisco-anitype=4
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=9763495
cisco-desttype=0
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
*Dec 16 04:45:20.523: //-1/127ABE148015/CCAPI/cc_api_call_setup_ind_common:
Interface=0x4CE0A3B8, Call Info(
Calling Number=7662228,(Calling Name=)(TON=Subscriber, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=9763495(TON=Unknown, NPI=ISDN),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*Dec 16 04:45:20.527: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Dec 16 04:45:20.527: :cc_get_feature_vsa malloc success
*Dec 16 04:45:20.527: cc_get_feature_vsa count is 1
*Dec 16 04:45:20.527: :FEATURE_VSA attributes are: feature_name:0,feature_time:1217509232,feature_id:35
*Dec 16 04:45:20.527: //79/127ABE148015/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=7662228(TON=Subscriber, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=9763495(TON=Unknown, NPI=ISDN))
*Dec 16 04:45:20.527: //79/127ABE148015/CCAPI/cc_process_call_setup_ind:
Event=0x4AD03A98
*Dec 16 04:45:20.527: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 9763495
*Dec 16 04:45:20.527: //79/127ABE148015/CCAPI/ccCallSetContext:
Context=0x4D03C814
>>>>CCAPI handed cid 79 with tag 0 to app "_ManagedAppProcess_Default"
*Dec 16 04:45:20.527: //79/127ABE148015/CCAPI/ccCallSetupAck:
Call Id=79
*Dec 16 04:45:20.527: //79/127ABE148015/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
*Dec 16 04:45:20.527: //79/127ABE148015/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=79
*Dec 16 04:45:20.527: //79/127ABE148015/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
*Dec 16 04:45:20.531: //79/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0x4F, digit_event=0x1, enable=TRUE, consume=FALSE)
*Dec 16 04:45:20.531: //79/127ABE148015/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=79
*Dec 16 04:45:20.531: //79/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x4CE0A3B8, callID=0x4F, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*Dec 16 04:45:20.531: //79/127ABE148015/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x4CE0A3B8, Call Id=79
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
*Dec 16 04:45:20.579: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 7662228 N/A
plz help me
11-16-2012 02:38 AM
I think you're missing the mandatory param voicemail in your aa script config.
You're debug massage doesnt give enough info really
11-16-2012 05:24 AM
tanx for reply, i debug again my router and i got this massage, can you cheak it? tnx
*Dec 17 02:33:41.343: //156//TCL :/tcl_PutsObjCmd:
proc init_perCallvars
*Dec 17 02:33:41.343:*Dec 17 02:33:41.343: //156//TCL :/tcl_PutsObjCmd:
11-16-2012 05:36 AM
You probably want to try something like the following...
application
param voice-mail 1234
where 1234 is your voicemail pilot
11-16-2012 08:52 AM
i try do it but it's not correct, tnx for answer
