allowing International & Internal calls only & blocking Local & National calls
Vijay Patil
Level 3
Level 3
We need to configue only single Extn with only Internal & International calling allowed ...& Local -National call block..
how can i do this
Vivek Batra
Simply assign only those partitions in device CSS which you want to allow viz internal and international. Since device CSS won't have having access to rest of the partitions viz local-national hence those calls will be blocked.
You can also utilize line/device approach depends on your requirement and deployment size.
- Vivek
Thanks Vivek,,
Already done the same & tested
Hi Vijay,
Thanks for updating us.
- Vivek
