IP Telephony and Phones
Labels
We are currently running firmware version SCCP75.8-5-3S and want to upgrade to firmware version SCCP75.9-4-2sr1-1.  We only want to upgrade a few phone right now.  Will this work? 1) Run Software Upgrade | Install Upgrade from OS Administration to i...
dtom by Level 1
  • 486 Views
  • 2 replies
Hi, I have 15.4(3)M4 / CME 10.5 on my 3925 router and my sh licence detail cme-srst shows 60 licenses: Feature: cme-srst Version: 1.0License Type: RightToUseLicense State: Active, In UseLock type: Non Node lockedVendor info: <UDI><PID>NOTLOCKED</PID>...
Dear All, I would like to collect live CUCM traces while phones or other end points try to register with it, and also help me understand/read the collected traces, because I sometimes find it very difficult when phones do not get registered. Thank yo...
Syed by Level 3
  • 2447 Views
  • 28 replies
We are using Cisco 3825 on which 1 E1 port configure & 5 FXO port are configured users DN are configured with the E1 PRI DID range. currently all incoming & outgoing calls are going through E1 port .... we need to configure in such way that only in...
Resolved! MGCP link to CUCM
Hi Everyone, I'm looking for a configuration that if the MGCP link with both Call Managers go down, to alert Telco that the link is down, so they don't send calls to that PRI and would know to roll over the lines to another PRI which terminates at an...
When I try to install firmware upgrade to the 9971 phone I get this error:  Software Installation/Upgrade Download Status  Error encountered: The selected file is not valid. MD5 Hash Value: 4f:e2:f7:f4:6b:f8:db:1f:35:0a:73:bd:03:b1:63:02 The MD5 Ha...
torleif by Level 1
  • 666 Views
  • 2 replies
Dear Friends. I have a concern for my FXO port when call are getting forwarded.Below is my scenario We have 2 FXO lines which is registered as MGCP on CUCM 10.5 IOS version :  15.1(4)M8, Whenever call is forwarded to an external number when the cal...
Hi, I have a CCM Cluster version.6.1.2 and I have a problem with an VG248, using MGCP as signal control. This VG248 in moments is rebootCisco VG248 has software version: 1.3(1)DSP firmware version : 3.6(25C)I ckeck the voltaje, CPU, status port of th...
So I have a user that constantly logs there self out of the hunt group while picking up call. is there a way to log her phone logged back in with out me needing to removing and re add there extension to the hunt groups?
