05-13-2016 02:00 AM - edited 03-17-2019 06:54 AM
We need to configue only single Extn with only Internal & International calling allowed ...& Local -National call block..
how can i do this
05-13-2016 02:10 AM
Simply assign only those partitions in device CSS which you want to allow viz internal and international. Since device CSS won't have having access to rest of the partitions viz local-national hence those calls will be blocked.
You can also utilize line/device approach depends on your requirement and deployment size.
- Vivek
05-13-2016 03:47 AM
Thanks Vivek,,
Already done the same & tested
05-13-2016 03:57 AM
Hi Vijay,
Thanks for updating us.
- Vivek
