08-04-2014 04:53 AM - edited 03-16-2019 11:37 PM
Hello All,
When I call from analog line to PSTN, call is going out normally.
But after IVR telling me to dial extension number I can't dial.
Bahlul
08-04-2014 10:28 AM
Can you describe the call flow? Is this CUCM, CME, etc. Are you having issues with DTMF calling out to other organizations or is the issue with calling in to your IVR?
Can you verify the dtmf config on the outbound dial peer.
08-05-2014 03:27 AM
This is CME version 9.1.
Call flow : 3905 IP Phone -> CME FXO Port -> PSTN
When I call PSTN number call works fine. But when I call PSTN number, and after this IVR telling me to dial extension number, I'm dialing but there is no result. I think that I can't send digits to IVR.
Bahlul
08-05-2014 04:06 AM
The DTMF may not be going from your phone to the PSTN, causing the issue. What is the firmware running on the phone?
Can you send a show run of the router as well as the following debugs for a call?
debug voip ccapi inout
debug voip vtsp session
debug voip vtsp default
Another test that you can do is to call out to a landline or mobile phone using the FXO, and then press digits on the 3905 phone. Check if you can hear any digits on the landline/mobile.
08-05-2014 04:21 AM
08-05-2014 04:36 AM
The outgoing dial peers need to have dtmf added to them.
08-05-2014 04:41 AM
How to add dtmf to POTS dial-peer?
Bahlul
08-05-2014 04:51 AM
With phone model 7962 everything works fine. But with 3905 it is not working normally. Sometimes when calling internal numbers I can't hear any sound, but opposite side hearing me. How you think is it depends on firmware?
Bahlul
08-05-2014 04:58 AM
So that isolates the issue to the 3905. Looks like the phone isn't sending the right payload or not sending dtmf as it may not have been negotiated itself.
I note that you have configured all your 3905 pools as dtmf-relay rtp-nte and sip-notify. We now need the debug voip ccapi inout
debug ccsip message
debug voip rtp session named-events
for the call made from the 3905 so we can see what is getting negotiated.
08-05-2014 09:18 AM
Hey Guys,
That's a problem with 3905 firmware, please upgrade firmware to 9.4(1), which has the payload issue fixed.
~jorge
08-06-2014 02:20 AM
Hello Jorge,
I've changed the firmware but there is no result. Still when I call PSTN number call works fine. But when I call PSTN number, and after this IVR telling me to dial extension number, I'm dialing but there is no result. I think that I can't send digits to IVR
Bahlul
08-05-2014 09:38 PM
Hello Sreekanth,
I checked the support forums of cisco, and everyone telling that the problem in firmware file. But now looking for it , but can't find it.
08-05-2014 10:08 PM
Hey,
The firmware is located here: http://software.cisco.com/download/release.html?mdfid=283734772&softwareid=282074288&release=9.4(1)&relind=AVAILABLE&rellifecycle=&reltype=latest
08-05-2014 10:13 PM
Many thanks Sreekanth,
I downloaded it.
08-06-2014 02:21 AM
Hi Sreekanth,
I solved the problem with two way RTP stream. Now the problem with PSTN calling couldn't resolve.
"When I call PSTN number call works fine. But when I call PSTN number, and after this IVR telling me to dial extension number, I'm dialing but there is no result. I think that I can't send digits to IVR"
Bahlul
