Analog port in SRST
alex goshtaei
Hi All,
I am using MGCP with CUCM 7.0. Should I configure "connection plar" under voice port configuration for analog ports FXO in SRST mode?
thanks
Alex
Hi Alex,
Yes. When the port is MGCP controlled it will be ignored.
hth,
nick
hi i have yhe same issue, i have a gateway srst and the ports are controled by the cucm with mgcp, every work just fine, but when then connection fails, and the router up the srst mode i can get anything , becouse the comandas connection plat under the ports, are not reconized becouse are in mgcp, ??there is any solution ???
