ATA 186 problem with outgoing calls
vmtimaan2k4
I have an ATA 186 running on SCCP connected to a CME (2801 router),
I've connected two analog phones on the two FXS ports on my ATA.
My problem here is that when i make an outgoing call on
one of the two phones connected to the ATA, the other phone that
is not in use wouldn't have a dialtone. However when I call the phone
without a dial tone, it rings.
sivakarthiks
can you give your CME configuration with show ip telephony output.
sivakarthiks
can you give your CME configuration with show telephony-service output.
