ATA 187 only useable with CUCM?
andywander
I have a need to adapt analog telephony devices to many different SIP telephone systems.
I ordered an AT 187 based on teh descriptions on the web site, and the "9incorrect) links found through website search that led me to teh ATA 186/188 Admin guide.
Anyway, now that I have the ATA 187, and I have managed to track down teh correct admin guide for it, it appears that it will ONLY work with CUCM or CME.
Is this true? If so, what a disappointment. Is there another Cisco product that will work with ANY SIP server/system?
6 Replies 6
Chris Deren
Ata with sip load can be used with other third party systems.
Chris
How do I set it up? The docs only deal with CUCM and a tftp server.
Chris Deren
You have to look at the 3rd party vendor's documentation.
Chris
So I think what you mean is that the 3rd party SIP system needs to be ablle to support the tftp config method, just like CUCM would?
You can send the config from any TFTP, just change the tftpURL by going to http:/dev.  I would suggest you check the compatibility of your SIP server if ATA is listed, you will also have to convert the default SCCP load to SIP, for which you can search this forum as this has been asked many times.
HTH, please rate all useful posts!
Chris
OK, well what I don't get is how to :make" teh config file.
I am trying to register this with Onsip web-based SIP service.
