ATA 190 & CUCM 14
Gordon Ross
Level 9
Level 9
Since upgrading to CUCM 14, my ATA 190s can't register. Watching a packet capture, they download their config from the TFTP server fine, but then just sit there and don't attempt to contact a subscriber to register.
All my other ATAs (186,187 & 191s) are fine.
Any thoughts?
Gordon
Please rate all helpful posts.
IT.NRW [T43]
Hi Gordon,
i have test some cases with the ATA. If i disabel the mixedmode in the Callmanager the ATA will register.
Kind Regads
Sven
IT.NRW [T43]
Hi Gordon,
did you try the following steps?
1. go to the "phone security configuration" in non-working  ATA190 and change transport setting from "TCP+UDP" or "UDP" to TCP only, this will force the ATA 190 to use TCP for CUCM communications. Although both TCP and UDP transport protocols should work, there can be intermediate security devices are doing something different for SIP over UDP and TCP.
2. Update the CTL file in the Cluster by running the below command from the CLI -  utils ctl update CTLfile
3. Once the CTL file is updates, kindly restart the below services
  • Restart CAPF,
  • Cisco TFTP
  • Call Manager services
    then try to reset the ATA device afterward
tedmcinnes
The easiest resolve it to downgrade firmware of ATA back to pre 14 release and then do a factory reset on the ATA to get it too register
