12-18-2017 08:24 AM - edited 03-17-2019 11:48 AM
Hi Experts
I wonder if you would be able to help with this issue.
We have deployed ATA 190 for Fax use on SIP sites and these work fine and send and receive.
But our other sites are on ISDN and the ATA 190 will send but can't receive fax.
Everything is the same with these ATA's on call manager with the ones on SIP.
Are ATA190 compatible with ISDN?
Mark Cranswick
12-18-2017 08:51 AM
12-19-2017 02:12 AM
Hi thanks for reply, T38 Fax relay is what we have been using.
What should the correct setting be?
12-19-2017 02:36 AM
