Bookmark
Subscribe
1908
ATA 190-SC
scheived
Level 3
Level 3
Anyone know if these ATA 190-SC models, with the 1 analog port can be used on Communications Manager?
BigK
it should work. I used one on CUCM 11.5 for fax. Just make sure you use STANDARD ATA 190 SIP as your phone button template in the device information.
Rate if this is helpful.
Karim
Never did get it to work, I just returned the thing.  Beware of these "SC" models!
ATA 190-SC is Spark Call(WebEx Calling) only, not the SC in the part number.
